Question about Tablets & eReaders
Can I get a replacement battery for my tablet?
Where can I purchase a pt425080 battery for a rca tablet
Everywhere! :>)
For RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V ...
Listed is a RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V 2600mAh - Used. Is your battery not holding a charge anymore? Are you just looking ...
RCA RCT6378W2 Battery Replacement - iFixit RCA RCT6378W2 Battery Replacement: In this guide you will learn how to remove and replace the battery in your tablet.
Battery Tablet 7 ' eBay 3.7V 3000 mAh Polymer Li ion Battery Lipo For GPS PDA PSP iPAQ Tablet 7" 8" ... Battery Type: Li-ion Polymer Battery. 1 x 3000mAh Li-ion Polymer Battery.
RCA 10 Viking Pro 10" RCT6303W87 Internal Battery ' eBay > ... > See more RCA 10 Viking Pro 32GB WiFi Tablet Keyboard Bl... Rating: 4 - ‎5 reviews
ITEM DESCRIPTION. Item was pulled from a working unit and is in great condition. THIS BATTERY HAS TO BE SOLDER. Please check the battery in your tablet, ... 4200mAh battery for RCA RCT6203W46 10 ... Rating: 3.7 - ‎3 reviews
RCA PRO10 Edition RCT6203W46 10" Tablet PC Digitizer Touch Screen New ... $19.99. 3650mAh Replacement Battery for RCA RCT6272W23 7" Tablet PC ...
RCA ' How to take care of your tablet's battery Learn how to take care of your RCA tablet's battery with these simple and helpful tips.
Bulging batteries in RCA tablets ' KOMO May 19, 2015 - If you have an RCA 7 inch tablet that was purchased last year- keep an eye on the internal lithium battery. There are reports of the battery ...
Jul 29, 2017 | Tablets & eReaders
Samsung ativ 500t smart tablet won't turn on after installing new battery
A lot of thing could have happened when you opened up your Tablet. Samsung makes it tough to change out batteries in Tablets.
Jun 05, 2016 | Samsung Tablets & eReaders
How can I replace battery?
Not sure of your model and size..
however See; Learn and Decide using
Samsung Galaxy Tab 3 10 1 Battery Replacement
Choose the appropriate battery from ebay Galaxy Tab Battery eBay
Apr 16, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How to change the battery in this tablet
Would depend on the make and model Barbara which we don't have.
I can recommend for replacement batteries for phones and tablets.
make model replace battery
and look at the YouTube videos.
Feb 04, 2016 | Tablets & eReaders
Tablet will not charge and will not turn on at all thinking battery has went bad how do i get this fixed--Janie Anders
Actually it might be the charger or even the cable. The problem with some tablets is tha battery is not "user serviceable". So, my advice is that before taking to repair your tablet, check the chager. Some chargers are quite standard, same as used by cell phones. No idea what kind of a charger does your unspecified tablet uses.
If you can replace it, ok. If no, check output at any service store; they have voltimeter to do it.
If definiitively is the battery, verify the cost of replacing it. Some tablets are really cheap and to change a battery might cost you more then a new tablet.
Jul 09, 2015 | Tablets & eReaders
Change battery in irulu 10.0 tablet
Hello Sonny,
These tablets have a "life long" battery, meaning that it is not user replacable... Looks like it is time to get a new tablet.
Best regards,
Oct 24, 2014 | Irulu 10.1 inch Android 4.0 Touchscreen...
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
How to replace kocaso battery for m9100
You don't, you may damage the tablet by attempting it.
Try the solutions here for apparent battery problems.
Support Troubleshooting Guide
Mar 30, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Tablets & eReaders Logo
20 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
