Question about Dell Dimension 4700C PC Desktop
Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL and was sent a modem. I installed modem but still not able to connect to internet. Verizon support tells me modem does not recognize network interface card. What can I do? Thank you very much for any help.
  • rrutkowski Jul 24, 2009
    I cannot try any of your suggestions until tomorrow, which I will do then and respond to you. I do want to thank you for staying on top of this.
  • Fernando Torres
    Fernando Torres May 11, 2010
    First thing we need to check is what OS you are running and whether the Network Device and Driver is installed. Now telephone modem is DSL.. can you provide details on that because if you say you installed the modem that it should work. Also, have you run the IPCONFIG command if you system has a microsoft OS
  • 724 Answers
I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
Posted on Jul 24, 2009
Ethernet connection?
An ethernet connection is used to connect network ready devices to a network. The Ethernet connection looks like a phone jack, but is not compataible with telephones, only network cables that are designed to fit that type of socket.
Nov 23, 2012 | Philips Hdt8520 500gb Pvr Freeview Hd...
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
Oct 25, 2010 | AT&T High Speed DSL Modem
My dsl light keeps blinking and I can't get on the internet because it won't stop blinking
  1. Step 1 Ensure that your AT&Tmag-glass_10x10.gifDSL self-installation kit is complete. At minimum, it should contain aDSL modem, an AC adapter, an Ethernet cable, a telephone cable, severaltelephone filters and an installation CD.
  2. Step 2 Installthe telephone filters on each telephone jack that you have a phoneplugged into. Install a dual phone adapter on the jack closest to yourcomputer if you have an answering or fax machine, telephone or analogmodem in the same room. Then plug your telephone equipment into thefilters. Connect the telephone cable that was provided with yourinstallation kit into an unfiltered telephone jack.
  3. Step 3 Insertthe installation CD into your CD-ROM drive. If the installation programdoes not start automatically, click Start > Run > and browse tothe CD-ROM drive directory to find the installation file.
  4. Step 4 Connectthe telephone cable that is attached to the unfiltered wall jack to theback of the DSL modem. Connect the Ethernet cable to the back of themodem and to the Ethernet network interface card port on the back ofyour computer. Connect the AC adapter to the back of the modem and plugit into an electrical outlet. Power the modem on.
  5. Step 5 Checkthe modem lights. There should be at least two lights lit. These willhave labels such as "Power" and "Ethernet." However, these labels maydiffer depending on the model of modem you received in yourinstallation kit.
  6. Step 6 Completethe software installation. Enter your chosen username and password whenprompted. Check your modem to see if the light labeled "DSL" or"Internet" is lit. Open a web browser window to see if your DSL servicehas been successfully installed.
Jul 06, 2010 | AT&T High Speed DSL Modem
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
New, second modem won't recognize modem
You probably need to install network adapter driver on your new hard drive.
Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
Dec 27, 2009 | Dell (S423) for Dimension 8100 (3F546)...
How do i connect my router to my telephone line
The telephone line doesn't connect to the router. The telephone line goes to the modem which is provided to you by your internet provider. Then an ethernet cable is connected from the modem to the router.
The modem allows the internet connection to be active, The router is used to distribute the Internet to create a network.
Sep 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Yes i want to find out if a cable modem will work with your dsl phone internet service?
No.
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Need to replace hard drive on T2778 Emachine.
You need memory modules with maximum 1Gb DDR 333Mhz.
For HD you can select whatever you like.
Just replace memory modules, install your new hard drive (if it is IDE set as master).
After that get in to the BIOS (normally press DEL when boot the computer) and from boot order select as first the CD-DVD ROM and as second the Hard Disk.
Put at the CD Device the CDROM with the windowsXP and restart the computer.
The guide to install windows XP is very clear but if you have more questions post again.
Jan 11, 2008 | Computers & Internet
Dell Dimension 4700C PC Desktop Logo
299 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
