How do I display the time after I have switched to standby mode?
Model No: DMR-XW380
SOURCE: my panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Posted on Sep 28, 2009
hmerchant110
  • 7191 Answers
SOURCE: require an operation manual for a panasonic dvd
You can download and print the operation manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on Nov 24, 2010
Wolfman304
  • 720 Answers
SOURCE: I Lost my User Manual
Try downloading from this link (tick the acceptance box then click 'view'):
http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=191450&fmt=PDF&lang=en&src=3
Cheers,
Posted on Jun 14, 2011
  • 963 Answers
SOURCE: How do I get the panasonic dmr-hw100 to display the time or channel description
Here is the web link to download the owner's manual :
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_222458
Click on the "View 4.7 MB" button to be taken to the next page where you will "accept" the .PDF download.
If you are unable to view the PDF instructions, you need to first download and install Adobe Reader. There is a direct link to be found just under the "View 4.7MB" button, where it says
"get_adobe_reader.gif Operating Manuals for most Panasonic products are now available On-Line in Adobe PDF format. If you have the Acrobat Reader installed on your computer you may view the document directly. You can also chose to download the file to your PC for future reference or printing. Acrobat Reader is available free of charge from the Adobe website. A link is available on the left."
Good luck--and please provide feedback if this helps!
Posted on Dec 27, 2011
  • 6771 Answers
SOURCE: set on standby mode,no display aiwa nsz-20hr
There is a short in the power supply board, shorted regulator transistor, or diode, and capacitor, "sometimes a bulge at top" cheaper to replace than repair.
Posted on Apr 03, 2012
I have a Panasonic DVD recorder Model DMR-XW380. I was wondering how I get it to play multi region dvd's
go online to panasonic support and download the owners manual or just google the model you will find a free manual download
Dec 05, 2017 | Panasonic Televison & Video
Increase size of hard drive
It might be able to be done but the best way it to get a external usb hard drive. If your system will let you. I don't think you can put another HD in it because the software that makes your system run is on the orig. one no way to transfer from one to another with out a high price HD copier.
Feb 19, 2015 | Panasonic Dmr-XW380 Dvd Recorder
How do I fix my Panasonic DVD Recorder DMR-XW380
U99 Hi. This indicates a communication error between the timer and main processor unit. Try unplugging from the wall for a minute or two, and plugging it in again, to reset everything.
Sep 12, 2014 | Televison & Video
Stop button on my remote has stopped working, so using the pause button now then have to push again to play. Does this mean the remote is stuffed?
Probably. You could try spraying some switch cleaner (from electronics stores) into the gap between Stop button and body of the remote, but if that fails, try eBay or similar sites for a replacement
Aug 05, 2013 | Panasonic Dmr-XW380 Dvd Recorder
Record and play at same time?
Are you asking if the machine will do this?
Jul 05, 2013 | Panasonic Dmr-XW380 Dvd Recorder
Does it cost for this advice/service
make sure at least one records in DR mode
Jan 04, 2013 | Panasonic Dmr-XW380 Dvd Recorder
Will not record two programs simultaneously
make sure at least one recording is in DR mode
Aug 08, 2012 | Panasonic Dmr-XW380 Dvd Recorder
TV screen goes blank, still have sound. Is it our freeview box or the TV.
There are some firmware updates available for the DMR-XW380 that you might want to consider at least looking at.
http://panasonic.jp/support/global/cs/dvd/download/xw480/index.html
May 16, 2012 | Panasonic Viera TC-37LZ85 LCD TV
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
