Question about The Toys
Replacing the rotor blade on the air hog SW Tie fighter
Cannot remove rotor blade
  • 30 Answers
SOURCE: air hogs rotor - pulled wires
first just shove the wire back in and try to wiggle the motor back in and it should appear to be untampered and if you still have the box there is a number on the back, you just tell them the rear motor didnt work and they will send you a new one or you can put it back in the box and take it to wherever you bought it and tell them the same thing and then theyll give you a new one if you cant find the number here it is: 1-800-622-8339
Posted on Dec 30, 2008
SOURCE: Are main rotor replacements available for Air Hog
yeah check out
Posted on Dec 29, 2009
SOURCE: my air hogs hawk eye
air hog hawk eye helicopter keeps cutting out when fully charged for no reason
Posted on Dec 23, 2010
SOURCE: need the top rotor blade
i need a top rotor blade for my RPT6 helicopter
Posted on Mar 27, 2011
  • 10 Answers
SOURCE: My Air Hogs Hawk Eye helicopter's lower rotor
Okey, this is a trickie one, now inside the lower rotor shaft the white plastic gear goes up in to the larger shaft and has like a simi circle on top, ( i know im not discribing it well but trust me the little "tooth" most likely has broke and it randomly binds up in side the shaft, had the same thing happen to mine, i fixed it by dissembling the rotor assembly and removing the broke "tooth" and putting a drop of crazy glue on the ******!!!!!! worked for me
Posted on May 11, 2011
Copter of air hog flew fine initially but after that top 2 out of 3 do not fly but for few turns on pressing the launch button.On pressing the throttle the bottom wing would fly in anticlock direction
gyro working ok other wise ?
see this link for answers
Air Hogs support
thought the two blades top blades were rotation opposed on that
something like
the drive cog stripped
or rotor blade bent or other cause
Oct 09, 2016 | The Toys
Balance blade rotor broke
You can get a new balance beam on Ebay for a few pounds just search Air hog. Just check the linkages are ok before you order so you can buy them as well if needed. They are actually called a " Flybar"
Jan 03, 2014 | Air Hogs Hover Assault Vehicle
Need the top rotor blade for my NEW RPT6 AIR HOG.
Nov 17, 2010 | Air Hogs Toys
How do you remove and replace the main rotor on the Havoc Stinger? I wasn't able to find a replacement blade for this specific model. Will the replacement blade for the Havoc heli work. Mine is clear not...
I just experience breaking my 1st main rotor and replaced it.
What you need are a pair of needle nose pliers and a hair dryer.
Put the hair dryer on "HOT" and blow on the rotor plastic shaft for
about 1 minute. Then take the needle nose pliers, lightly clamp
them on the plastic shaft and lift. It should slide off the metal shaft.
Next I took the hair dryer again and heated the replacement rotor
shaft for about 1 minute and pushed in on the metal shaft with my fingers.
Hope this helps.
Dec 25, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Havoc heli flight problems
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Jan 05, 2009 | Air Hogs Havoc Heli Helicopters
Rotors spin just a little
make sure that the blades are snapped into place and that everything is charged and then make sure the heli is on because if you crash it, it will automatically turn itself off and then make sure no hair is stuck on the bar that spins thats attached to the blades and then try it again
Dec 26, 2008 | Spinmaster Air Hogs RC Reflex Micro...
Toys Logo
276 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
