Question about Freezers
How CAn I open the freezer door On a RF263beaesr to gain access to the latch assembly that connects to the handle the part number that snapped is da67o3435 cap handle
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Repairs should be performed by a qualified service technician. you may not need to disassemble the door. hold the handle and shift the handle left or right to remove the handle. do the same to reinstall the handle.
Posted on May 02, 2017
check and empty the drain pan, you should be able to gain access by removing the vent grill below the door if there is one. The pan is under the unit somewhere. There is also a drain tube, make sure its not blocked with ice.
Sep 06, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
I have an upright Kenmore freezer #253.21741106. I need to replace the electronic control. I see by the diagram that the overlay needs to be removed to gain access. How is the overlay held in place? Does...
the ken more should be a whirlpool at the bottom of the dispensor look up there are two notches take a screw driver in one notch with the other hand pull down and with the screw driver twist
this will release it
May 23, 2010 | Kenmore 14.1 cu. ft. / 399 liter Upright...
The door handle is partly pewter and has snapped off at the Anchor. size from screw hole to screw hole 300mm
As it is and old model the genuine part is not available so I have had to make a plan. I have used a built in cupboard handle in Stailess steel and modified it to work. Anchoring the handle from the front will not work, so I have had to srtip the whole door and place small indentations in the foam insulation with washers behind the anchoring nuts.336b095.jpg
Dec 03, 2009 | Freezers
Have an Amana Side by side refrig/freezer (model ACD2234HRS) that has a loose refrig door handle. How do you get access to tighten the door handle screws?
i believe there are plastic coverings that just pop off. they are located at the hinge,you will need to fully open the doors to get to them.
Sep 20, 2009 | Freezers
Bed room door locked
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Feb 18, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Need help, fast
Sounds like she put a hole in the evaporator.BAD NEWS!!! If it is accessable it may be repaired and the unit recharged. The proper way to defrost a freezer is to empty it and pull the plug with the doors opens.Let it melt on it's own.
Dec 10, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezers Logo
212 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
