Question about Sewing Machines
When my 9000 is switched on the regular sreen comes up the it beeps the this come up raise presser foot and needle bar,then turn power switch back on .have done so the same thing keeps repeating
5 Suggested Answers
  • 323 Answers
SOURCE: I turn on machine keeps
This machine needs to visit an authorized Janome technician.
sewman7
Posted on Jul 10, 2008
  • 19 Answers
SOURCE: says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Posted on Dec 23, 2008
SOURCE: raise presser foot and needle bar, then turn power
i too have the same problem from yesterday .. plzzzz helppp
Posted on Aug 13, 2010
99rannellis
  • 8899 Answers
SOURCE: When I turn on my machine this warning comes up raise the presser foot and needle bar then turn power on again #01
Sorry. Unable to advise. Error codes mean different things on different brand machines. Perhaps consult the owner's manual in the troubleshooting section.
Posted on Nov 29, 2015
When I turn my Janome mc 9000 the screen says raise presser foot and needle bar and switch it off and back on. I did this several times and it still says same thing.
Almost defiantly a sensor issue. These are not easy machines to work on due to their hi-tech design. Clean and inspect as much of the mechanism as you can as some cotton or fluff may be obstructing a sensor or switch. This may stop the machine from calibrating.
Below is a link to a PDF of janome error diagnosis. It is a bit complicated but one of these steps may solve your issue or offer a solution.
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj1mtPo-fLNAhXqDMAKHfgCBYAQFgglMAA&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Jul 14, 2016 | Janome Memory Craft 9000 Computerized...
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9000
Did you raise the presser foot and needle?
Oct 11, 2013 | Sewing Machines
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
Says raise pressure foot and needle bar
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
