Question about Samsung RS2630SH Side by Side Refrigerator
What are the steps to force a defrost in a Samsung
What are the steps to force the defrost in a Samsung RS254SH?
Samsung RS267LBSH/XAA evaporators (both the refrigerator and freezer sides) building up with frost. It works fine for about a week after defrosting with blow dryer, and then same problem happens.
Your defrost heaters are not working. The unit takes a week to freeze up and presto - poor cooling. Melt the ice and it works fine again till it freezes up again. Did you check out the defrost timer? Make sure that the defrost elements are not open.
Apr 30, 2017 | Samsung Refrigerators
How do you manually defrost a Samsung RF261 refrigerator and how long should the defrost cycle last.
Defrost cycles in normal conditions can last from five (5) to 25 (25) minutes, depending on variables like humidity, runs times and how often the door is opened. Defrosting the unit manually as you've done is merely a short term solution as it recurs again over time. You should find out why it is not working automatically, as intended. This could be a problem with poor air flow (fan, blower or restricted air), a bad control, or even loose connections. Forcing defrost without correcting the underlying issue will not eliminate the problem.
Dec 06, 2014 | Samsung Refrigerators
Howtoforcedefrostrefridge rf197acrs/xac
Unplug the refrigerator to manually defrost. You need to test the defrost parts to see if one or more are faulty.
There is a simple more accurate way to dx than forcing a defrost by advancing the timer/ADC.>>>Refrigerator Defrost Parts
Jun 20, 2014 | Samsung / RF197ACRS
Samsung RB215LABP ice in bottom of fridge but freezer won't get over 35
Step 1:
You almost certainly have a defrost issue with this unit. Your best bet with a Samsung is to call a qualified service tech to complete your repair. If you want to try it yourself here is what you would need to do to test this unit. If your unit is not defrosting it can not circulate the air and will cause the unit to warm up.
Step 2:
Unplug the unit and remove the back cover on the unit where the compressor is and you will see a white box on the right hand side. Remove the screws holding that box in and pull it out and open it up, that is your main pcb for this unit and all tests will be done from here.
Step 3:
Using a multimeter set to Ohms for measurements unplug the connector on CN70 (pnk, skyblu, org, wht, brn) and on the plug check for continuity from the white wire to the orange wire (Refrigerator Defrost Heater) and from the Brown wire to the orange wire (Freezer Defrost Heater) if either of those show open then that is your problem, replace the heater.
Step 4:
Plug CN70 back in and the plug the fridge back in. Using needle leads on your multimeter set to DC volts check for power on CN30 from Orange wire to the Brown wire (do not unplug the CN30 connector) your voltage should be from 2.3v - 4.2vdc (freezer defrost sensor). Also check the purple to the brown wire 2v - 4.2vdp (Refrigerator defrost sensor). If you are outside of that then you would need to replace that sensor.
Step 5:
If the above steps check good then you will need to put the unit into defrost and check for power at the heater. To put the unit into defrost, from the user interface panel on the front of the unit press the power freeze and power cool buttons simultaneously for 8-12 seconds until the display quits blinking. Press the the freezer button 3 times (wait 5 seconds between button pushes) to force the unit into defrost.
Step 6:
Go back to the main pcb and using your multimeter set to VAC check for power at White and Orange (refrigerator defrost heater) should be 110-120vac. Also check from brown and orange (freezer defrost heater) should be 110-120vac. If you do not have power then you have a bad main pcb.
Mar 25, 2013 | Samsung Refrigerators
We have a samsung fridge with bottom freezer the freezer is humming and when you open the door it stops and the temperture is rising when you shut the door the humming starts back in a few seconds
defrost issue , not sure on how to jump the board to force defrost but more than likely the defrost thermostat is bad . this is on the evap in freezer . the noise come from frost building up around the evap fan
Feb 25, 2013 | Samsung RB2155 Bottom Freezer Refrigerator
How to defrost (steps) chicken in samsung c103fl
Hi from retired Englishman in SW France, Friday afternoon 14:54
You have posted your 'how to defrost (steps) chicken in samsung c103fl' on the washing machine forum- I doubt you would have got an answer and your chicken has probably defrosted by now anyway ;-0)
You would have needed to re-post onto the appropriate forum but in any case why not try and obtain a user guide from the web for the future?
Type into your search engine/web browser ' samsung microwave user guide' and, with a bit of luck, you should be presented with sources from which you can download for free!
Good luck and sorry, I'm no cook- ask my wife!
John C
Mar 04, 2011 | Washing Machines
Samsung fridge, Model#RB215LASW/XAC has defrost problem. Is there any way to gain Fault Codes for this model?
Here's a link for the service manual....This is a complex device....
Kinda like a Prius....
There are tests modes and you can pull the error codes and force modes...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Jan 28, 2010 | Samsung RB215LASH
How do you force defrost a 4 door Samsung refridgerator RM255. I have the service manual but it is still confusing
go into freezer
take off back wall.
you will see the ball of ice around your evaporator.
hair dryer; plug in, turn on, go crazy.
Oct 07, 2009 | Samsung Refrigerators
Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
May 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Motor freezes up
the issue is not with the motor to be honest you have probably wasted money buy a new fan motor ,
the fan only stops working when ice builds up and forces it to jam , the ice builds up as the defrost heater is more than likely faulty - very common issue on all uk samsung rs21 models ,
to rectify the fault totally its recommended to replace 4-5 components that operate the fridge cooling /defrosting system - sounds complicated but its really just 1-2 hour job for a skilled competent person
have a look at this video , also check the youtube chanel for same guy , there are lots of info on samsung uk american fridge freezers
May 10, 2009 | Samsung Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
267 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
