Question about Garden
My blades will not turn on anymore just stopped working tractor still runs
    Master:
  • 412 Answers
Broken belt or came off the pulley. Suggest a mower repair shop.
Posted on Apr 18, 2017
Testimonial: "just came off pulley may disconnect some wires?"
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
MY TRACTOR RUNS FINE& STOPS LIKE IT SHOULD. THE BLADES DO NOT TURN WITH THE PTO SWITCH ENGAGED
if this is a newer mower then the problem is usually a safty switch is not being completed and this is stopping the blades from turning on, most mowers have a switch under the seat that has to be shorted out in order for the pto to work, this can be checked by connecting the two wires going to the switch together, and seeing if this solves the problem. Does it sound like the pto is trying to turn on if this is the case then you might find you have a siezed up bearing that is stopping the pto from engaging but my guess is a safty switch is malfunctioning and causing the pto tp not turn on, Hope This Helps Don
Nov 10, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
DGS 6500 (725 cc) Craftsman - motor stops running
if the ignition isnt turning on at start up check the dead stops.. there are several. mone under the seat one for the grass hopper and there may be on for the blade position and brake and gear selectioon. the one under the seat has a plate that actuats it this can sometimes move out of place. the one for the hopper can also stop the motor if the box aint on straight.. the height lever has one too.. these are probable causes.. if the motor turns check the gear that turns the motor this is on the shaft for the starter motor. it can sometimes stick so the rotor doesnt turn.. Good Luck .. A
Aug 01, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Blades stop working
Does your mower have an electric clutch ? If so your problem is most likely a connection
May 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
