Question about Whirlpool Kitchen Ranges
Is there a reset for a Whirlpool Gold Accubake Stove GR673LXSB1. Just changed oven control board and still not working
  • 711 Answers
Try this link for repair manual. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/manuals/&ved=0ahUKEwjbxrKM5LDTAhUH74MKHSrMA8IQFggfMAE&usg=AFQjCNF9HWfYhR5IzVds32BJy-kZG_jubw
Posted on Apr 19, 2017
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Why the off switch, temperature control dial, timer do not work when baking?
could be that it knows it is already being used and locks all controls until the timer runs down .
Feb 14, 2016 | Whirlpool Gold GGE388LX Double Oven...
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Whirlpool Gold Accubake System smooth top stove keeps kicking out the 10 amp breaker, sometimes with oven on, sometimes just a burner on, just started doing this a week ago, why????
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Aug 30, 2010 | Whirlpool Kitchen Ranges
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Jan 10, 2010 | Whirlpool GY396 Electric Kitchen Range
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Jan 10, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
