Question about The Computers & Internet
Value of 2 McCoy Crocks. One has a 12 on the front the other, 22. Can you help?
2 Suggested Answers
  • 547 Answers
SOURCE: need 2 crocks
I'm not aware of any on-line replacement parts for Hamilton Beach slow cookers, but you can contact the company at
and ask them.
Note that there are three models of slow cooker for that number:
Check the label on yours to make sure you've got the right one before placing your order.
Posted on Apr 17, 2010
You can convert this in a number different of ways, all giving the same result if applied properly. However people from the olden days that still used 8-bit computers often used following:
1.Split the binary number in groups of four digits, adding leading zeros if necessary. 11001100 => (1100) (1100).
2. Given the individual bits have values 8, 4, 2, 1 when set, convert the groups individually 1100 = 8+4 = 12. In your case, both groups have the same value,
3. Multiply the value for the left group by 16 and add the right group's value:12 * 16 + 12 = 192 + 12 = 204.
It helps if you know the multiples 1*16, 2*16, ...., 15*16 by heart.
Mar 22, 2014 | Office Equipment & Supplies
Facts about elijah mccoy
In case you are referring to the inventor Elijah McCoy (1844-1929), you may find some information here:
Elijah McCoy Wikipedia the free encyclopedia
If this does not help you, please clarify what is the "it" that would not tell you "what".
Mar 13, 2014 | Computers & Internet
Quadratic functions
Substitute 2 for x, 3 for f(2). This gives you an equation with a as an unknown
4a=3+12+7=22 or a=22/4=11/2
11/2*4-12-7=3 Checks OK
Oct 20, 2013 | Office Equipment & Supplies
Workshop manual for a 1994 nissan serena
Cylinder head bolt torque sequence
The Rod Bearing Cap Torque
The Main Bearing Cap Torque 38 Foot pounds (Final torque)
Step 1: Torque 10-12 Ft/LbsStep 2: Torque 17-21 Ft/Lbs
Note :
Torque sequence ------------------------
' 11 '
front ' 13 9 3 1 6 8 '
of ' '
engine ' 14 7 5 2 4 10 '
' 12 15 '
Step 1: Torque all bolts in sequence 22 Ft/Lbs
Step 2: Torque all bolts in sequence 47 Ft/Lbs
Step 3: Loosen all bolts in reverse sequence
Step 4: Retorque all bolts in sequence 22 Ft/Lbs
Step 5: Retorque all bolts in sequence 43-51 Ft/Lbs
Step 6: Retorque bolts 11 thru 15 in sequence an
additional 4-6 Ft/Lbs
** CAUTION ** This engine uses 2 different length head
bolts. "#1" Is the long bolt, while remaining bolts
are short. **Do not confuse location of these bolts**
recheck final torque in sequence
Dec 06, 2012 | Cars & Trucks
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
6+22)/ 2-12 x 3
Just follow the order of operations. 1. Parenthesis 2. Exponents 3. Multiply and Divide in order from left to right, and 4. Add and subtract in order from left to right. I'm assuming you are missing the left parenthesis before the 6 (.
(6 + 22) / 2 -12 x 3 =
28 / 2 - 12 x 3 =
14 - 36 =
Oct 28, 2009 | The Learning Company Achieve! Math &...
Tv says airflow restriction tv will turn off. there is no airlfow restriction
I did not find a reference to airflow restriction in the service manual.
I don't know if this will help, but here are the error codes:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
4. Error Codes
The Error Code designations are listed below:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hi I have an LG DVD±RW, it used to work properly but few days ago i tried to burn an iso. image it didn't work Device: [1:0:0] HL-DT-ST-DVD-RAM GSA-H55N 1.02(E:) (ATA) Firmware Version: 1.02...
According to the log file, there was a spindle servo failure. The spindle servo is responsible for maintaining rotational speed accuracy. I'd say your drive is pretty much dead. See if you can read a disk in the drive. I wouldn't be surprised if it had a tough time just reading files.
Jan 23, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
Starview ntl codes pls for 23/12/08...tnx
PURE NTL KEYS (UK) -- KEYROLL 23/12/2008
KEY 00 = 7F CD 76 82 BB 22 0A C5
KEY 01 = 97 9B 22 E0 5B 13 B1 C7
Chris (ziraffa)
Dec 23, 2008 | StarView SV431USB 4-port KVM...
Computers & Internet Logo
21 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
