Question about Water Water Heaters
My atwood hot water heater gets way too hot. Nothing has been adjusted to increase the temperature. Just noticed an odor and scorching hot water. Thought it might be the controller?
    New Friend:
  • 62 Answers
Sounds like calcium plugging. Drain the heater when it is off. Drain valve is above the outlet nozzle on the heater.
Posted on Apr 18, 2017
Rheem 21vp40 1
Copy following links to identify type of thermostat, and see how to adjust temperature on that specific thermostat, and see other ways to increase amount of hot water
Add a comment and describe if water heater is gas or electric, and add what other problems you are experiencing.
Jul 14, 2013 | Water Heaters
I need to flush my Atwood L/P Gas water heater MPD 93756 I'm unable to locate where you add the vinegar. Can you advise!
Remove hot pipe connection, and flush out through drain valve.
Or remove TP valve and flush out through drain valve.
Connect small circulating pump to 5 gallon bucket with 2 gallons white vinegar like they do with tankless water heater, as shown following Bosch manual. And let run for 45 minutes.
White vinegar is safe for humans.
If odor is the problem, use H2O2 hydrogen peroxide, and not bleach. Hydrogen peroxide is safe for humans and easy to flush out of water heater and pipes. While it can take weeks to get rid of bleach, which is caustic and toxic.
Oct 26, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
On a jade model j-81 the lever on the top what does it adjust
Hi Michael.
The lever usually controls the set-point for that water temperature inside the water heater. Move the lever clockwise to increase the temperature and move it counter clockwise to reduce the temperature.
The lever is pointing out behind the frame at left bottom in the picture at the link:
Good luck and regards,
May 12, 2012 | Water Heaters
We need to set water temp but can't find where to do it on the heater
The Atwood temperature adjustment is on the gas valve.
There is a metal lever sticking out.
Move the lever one direction, and if burner turns on, then move lever other direction to lower temperature.
If your gas valve is different, you might find answer on following page:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood model GC6AA-10E and the water is not hot enough on either gas or electric. Is there any temp adjustment on this unit?
Your 2 separate thermostats are pre-set so adjustment isn't possible although you can purchase a hotter thermostat. Normally the complaints I get are that propane is not hot enough, but electric is too hot, so I'm wondering if perhaps you haven't got a valve at by-pass in wrong position, or defective that may be allowing cold to mix with the hot. Make sure any valve in between hot (top line) and cold line (bottom) are all the way in off position. You want flow in to bottom open, and out the top open, and anything else in between, shut off. Have you actually tested a cup of hot water from tap to see what temperature it is? I just don't see both thermostats as being faulty at same time, but?
Dec 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
Hi, I have an old Atwood gas water heater (model j81 I think) this is a manual unit which we have to light the pilot light on. It will light and we can heat water for a short time only before it goes out...
That is not a model number that sounds familiar. Should be a tag on side of water heater behind cover, outside. If it has the little arm adjustment for temperature on top of gas valve, simply move it over a little to the left to increase water temperature, and try it until temperature is what you are happy with.
I'm assuming when you say it goes out completely that the pilot remains on and water heater re-lights when called for? If you adjust that temperature lever over, and water still doesn't get hot, you need to replace gas control, as thermostat is built in to it.
Dec 07, 2010 | RTO Water Heaters
I have an Atwood GGA-8E about 6 months old was getting hot water but now the water is only luke warm, any adjustments?
There should be a temperature setting on the gas valve. It should be on top or front and have several settings normally vacation, warm and hot. Rotate dial towards hot setting to increase water temperature. Hope this helps. Thanks
Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a new Atwood 6-gal propane water heater (still under warranty). It works fine except that when warm water is flowing, the burner will start heating only after the water gets quite lukewarm. Can one...
If it's manual light, then only dial or lever on gas control is adjustable, and you can try turning it up a little at a time. It will increase water temperature so be careful, but that should also make it kick back in sooner as well. If it's electronic ignition, there is 2 or 3 heat settings available in thermostats ( little disc behind foam cover under pressure relief valve) . Obviously on those, if you choose higher temperature, it cuts back in sooner as well. If you have electric element, they have a thermostat on rear of water heater as well, behind electrical connection box. If your not 100% sure what I'm saying here, get back with model number of heater inside cover and I'll tell you your options. Please remember to be careful of scalding when you turn up the temperature.
Oct 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
Does the atwood electronic Rv water heater have a temperature setting? Brad
Oct 18, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
52 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
