Question about Kenmore Washing Machines
Have a 4 wire lid switch yellow blue red and white wires which ones do I join to get my washer to wash clothes piling up thanks kenmore model 11026002010
  • 54 Answers
Your gonna have to read the diagram ... normally the white is neutral and the rest of leads.
Posted on Apr 18, 2017
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Kenmore washer Model 110.5072010, lid light keeps blinking and will not start.
Sorry! Your Worng ! There is 4 wires on the lid switch for
Modle # 110.5072010 The wires are in the right corner as you remove the control cover (puddy knife works to remove this) there they are all 4 wires Blue , Yellow, Green and White. .. makes 4 wires 1,2,3,4 like that.
Now how do you BY-BASS that one?
I would like to know this answer because the lid switches are a bunch of junk and cause me lots of down time and repair/trouble shooting time I don't have for a washing machine that is only 1-2 years old.
Sep 22, 2013 | Kenmore Washing Machines
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
Nov 18, 2012 | Maytag Centennial MTW5800TW Top Load...
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
My kenmore washer won't drain.
The top reason why that washer will not drain is gonna be the lid switch. Why you might ask?
The motor on your machine runs in both directions as it does triple duty. It washes it pumps and it spins. In one direction the tub is locked and the agitation washes them clothes.In the other direction it pumps and spins. The original models would pump and spin at the same time. This strained the motor so the newer models have a neutral pack installed in the tranny to allow the water to be drained first before she takes off. A momentary pause shifts the tranny fom pump to spin. If the water does not pump out it is because the lid switch is broken. Older models will allow the washer to wash but no spin with the lid open. Newer models won't allow for wash or spin. themobilian_1807.jpgthemobilian_1808.jpgthemobilian_1809.jpgthemobilian_1810.jpgthemobilian_1811.jpgthemobilian_1812.jpg
After you remove the case you will notice the lid switch quick connect has 3 wires. 2 hot wires and a green ground wire bolted to frame.
I jump the 2 hot wires so I can run the washer with the case off. I can
locate leaks and noises and observe the washer in action with the case off.
Video how to change a lid switch:
How it works, more videos, and a service manual HERE
Mar 10, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore series 80 washer will fill up and wash but it stops when it gets to the spin cycle. I have to empty the water by hand. Any ideas about why my washer will be appreciated.
Your washer uses a lid switch which kills power to the motor if you open the lid while it is in spin. These lid switches fail. They have 3 wires. One green wire that bolts to frame for earth ground and 2 live wires. Touch them two live wires together and it will effectively bypass the lid switch where you can wash clothes but it would be dangerous to children.
Manual and more repair photos click here
Let me know
Jun 10, 2010 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
46 people viewed this question
fordexpert
Mike Squire
Robert Rankin
