Question about JVC Televison & Video
Our LT42DV8BJ JVC tv went off and wouldn't switch back on
My boys were playing xbox on our LT42DV8BJ JVC tv (just about over 1 year old) and it suddenly went off. It wouldn't switch back on, blue light comes on the power button for a second and goes off immediately, tried to switch off from the plug, remote control or manual power button - no results. Could it be something blown up inside of it?
Thank you in advance
Mrs McKay
  • nigarmckay Jul 24, 2009
    This is not the case as other equipment works fine and all electrical in the house just over a year old and of a good quality. The TV would only make one attempt to switch on, i.e. green/blue light, then off in 1 second, and wouldn't react on any following attempts unless switched off the plug and back on again. Is there a 'reset' button in tv as such? Children said they had it very loud (probably max volume?), could the speakers vibrate and trigger some malfunction within the tv set?
  • nigarmckay Feb 22, 2010
    All over, fixed by the manufacturer, took them 8 weeks to find the problem and fix it in the end, they were nice enough to get it done for free too! :-)
    Sergeant:
  • 280 Answers
This my be the power supply board. Capacitors will get leakey and wont let the set start up.
Posted on Jul 24, 2009
The discs wont spin in the xbox
If your xbox is less than 1 year old you are still covered by microsoft warranty, visit www.xbo.com/support to book a free repair.
Thumbs up if this helps.
Feb 06, 2010 | Microsoft Xbox 360 Console
MY XBOX WONT PLAY ON MY JVC TV MODEL AV-25F1EK BUT WILL PLAY ON MY SONY TV
Is your JVC a HD TV? If not, it may because you haven't switched the xbox av plug in the back to regular tv instead of HD?
Nov 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
Turned TV off, went to turn it back on the next night and nothing
yes it could because if you did somthing to the fuse it could cause this problem
May 19, 2009 | Microsoft Xbox 360 Console
Unable to switch to Aux in order to play xbox 360
http://books.jvcservice.com/Download/566962143/LCT1467-001A-A.pdf
at JVC Support Page , download owners manual , listed above , on page 35 , it appears you should press INPUT button and cycle thru TV / video 1 / video 2 / V2 component / and video .
depending what video input option you used to hook up your Xbox to , you should be able to figure it out from here.
Dec 26, 2008 | JVC TM-2703SU 27" TV
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Televison & Video Logo
123 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
