Question about MotorGuide Electrical Supplies
How do you remove the top gear on a motorguide FW71FB trolling motor to change the lower top cove
  • 10 Answers
SOURCE: Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Posted on Mar 26, 2009
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
SOURCE: On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Posted on Jun 17, 2010
SOURCE: motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Posted on Jan 01, 2011
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
Motorguide trolling motor
They invite you to call them if you have questions... http://www.motorguide.com/about/contact but be sure to have your serial number ready.
Jul 16, 2014 | MotorGuide Boating
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Motorguide w75 trolling motor will attempt to steer but seems to not geting enough power. batteries show full charge. what advice can you give me?
Plastic steering gears are probably stripped. Metal gears are available, and are easily replaced. Contact me at groshartl@gmail.com
Oct 15, 2010 | MotorGuide Motg W 75 Wireless 60"
Only have 5th gear on my trolling motor its a 5 peed but 1 thru 4 do not work already replaced the switch
I have the exact same problem gears 1 through 4 don't work but 5th gear works fine, any help from anybody would be greatly appreciated. There are 4 red wires going into the switch also a yellow and a blue. The 4 red wires all have power going through them in 5th gear but when I switch to the other gears only the two middle wires have power.
Aug 14, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Triton72
Mar 26, 2009 | Boating
Electrical Supplies Logo
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
