Question about Hisense Televison & Video
Sound went out on my hisense 40 inch nothing in menu works
SD Tech
  • 14553 Answers
SOURCE: hisense 40 inch tv wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set isopened at least look for puffed up and bad caps like in this photo5_21_2012_3_41_35_am.jpg5_21_2012_3_42_12_am.jpg
Posted on May 21, 2012
vinceisaac
  • 2432 Answers
SOURCE: The sound went out on My 3 year old 40 inch sharp aqous
have you been check the speaker if worn out. if ok you can hooked up a powered pc speaker at the audio output jack of the tv . now if you can get sound there the cause it could be bad amplifier circuit. but if you can not get sound there the cause would be bad sound processor in the main board.
Posted on Oct 01, 2012
  • 5 Answers
SOURCE: Trying to find out what type of sound bar that will work with my tv
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
Posted on Feb 26, 2013
dduncan774
  • 760 Answers
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Posted on Mar 20, 2013
  • 4 Answers
SOURCE: Ive got a 40 inch led hisense that will not turn
It's likely that the power supply is faulty and would need replacing by a qualified technician .
Posted on Aug 22, 2014
I have a 40 inch hisense TV I have pic but no sound it was working fine last night I went to work n came home n no sound now. Help please
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
May 04, 2016 | Hisense Televison & Video
My picture went out on my 40" Hisense LCD tv. Dont know if has sound. I dont have cable. Any help?
YOU need help! How do you know you have no picture but do not know if it has sound? Just what do you know other than how to waste folk's time.
Dec 30, 2015 | Hisense Televison & Video
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
I do not have the original remote how can I get it off of video I believe its locked it says there's nothing connected
have you not got a menu button on the tv but if you don't go to walmart they have a remote that will work.
Jan 09, 2015 | Hisense 40K366W 40" 1080p Wi-Fi LED TV...
Mar 20, 2013 | Hisense Televison & Video
Feb 26, 2013 | Hisense Televison & Video
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
May 03, 2011 | Televison & Video
Sound does not work on several channels on Hisense LCD1504
RESTART THE AUTO CHANNEL SEARCH IN YOUR MENU. LET ME KNOW IF FIXED. THANKS.
Jan 19, 2009 | Hisense LCD1504 15 in. Television
Televison & Video Logo
23 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
