Question about Frigidaire Refrigerators
How do i rest my ice maker on my frigidaire Model #PLHS68EESB5 Serial # LA52619570
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Ice maker... its makes the ice but then doesn't dispense it the whole way.. its like it gets stuck sitting there and doesn't want to keep rotating, i have to lift or "reset" the wire ... its a model # M1
Good Afternoon Sean, thanks for your inquiry!
I understand that your icemaker is not dispensing ice and it gets stuck rotating. You have provided me with a model number of M1 and I was unable to locate any information on that icemaker. May I have the model number of your refrigerator? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Mar 15, 2015 | Frigidaire Ice Maker / Icemaker 5303918277...
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped making ice
Here is a check list to use to verify ice maker is good or bad or if something else is causing the problem.
1) Has the water filter been changed recently, or does it need to be changed? The filter being old can cause a reduction on water and lower performance of anything else that requires water.
2) Check the temperature in the freezer. Even though things are frozen in there, the ice maker requires that the temperature be at least 10 degrees F to even cycle. Ideal would be around the 0 degree mark.
3) Check the fill tube where water comes into the ice maker. From time to time this will get blocked due to water freezing in the tube itself.
********* If the first three checks all pass, either the water valve is bad and not allowing water to come to the ice maker, or the ice maker itself is not calling for water **********
Depending on the age of the machine it might not be a bad idea to change the water valve and the ice maker together.
May 30, 2012 | Frigidaire Refrigerators
On my Frigidaire Ref/Frzr Model number FRS6LR5ew5-Ice maker is not working???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Frigidaire FRS23H7CS Side by Side...
I have a 2003 Fridgedaire Galley side by side Model # GS23HSZCWO SERIAL # LA32403124 when my ice cube maker empties some cubes get caught in the fins, it will not make more ice until they are manually...
Contact Frigidaire, they did have some revisions on some of their models for issues with the ice maker, at least explain the situation and they may help with the cost of yet another ice maker.
Also be sure the ice maker is mounted level and watch for hollow ice cubes that would indicate a low water pressure situation and not be a fault with the ice maker but an issue with the filter, water connection, or possibly the house pressure.
Jun 11, 2010 | Frigidaire Refrigerators
I have a brand new (2 days) Frigidaire Gallery series, 23CU side by side that is not making enough ice. We are getting water from the door, the ice maker will only drop about 3 times in 24 hours. the...
Good day,
Light usage in a cool kitchen will reduce ice production substantially.
When the ice maker harvests, it turns on a calrod unit located on it's bottom, that frees the cubes, and as well the heat from the calrod heats up an internal thermostat in the ice maker to a temperature in excess of 70 degrees.
Then it stays at rest, until the cycle thermostat reaches 12 to 14 degress and then performs another harvest cycle.
If the machine runs little, and the fan in the freezer is not circulating cold air, the harvest times will be extended.
Turning the freezer colder will always help.
There is a possibility, the thermostat in the ice maker is out of calibration, and the ice maker needs replaced. But try the settings first, and give it a week or two, before calling for service.
You have a lot iof time under warranty to resolve this issue.
Thank you for using FixYa.
Jan 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water Dispenser with mind of it's own
one test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Nov 03, 2008 | Frigidaire Refrigerators
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
