Question about Grilling
Can't get started.
Hooked up propane followed instructions if you can call them that and heard a burst of propane then nothing. propane is going the right way through regulator. please help!
    Habit-Forming:
  • 100 Answers
Not sure what you are connecting, but there is normally a safety button on the bottom of the regulator, push it in and the gas will flow,
Posted on Apr 18, 2017
Hooked up new bottle,will not get hot,low flame
Turn off burners. Turn off gas. Disconnect regulator from propane tank. Reconnect regulator. Turn on burners Turn off burners. Turn on propane SLOWLY. Turn on burner and ignite.
Aug 18, 2014 | Weber Genesis E-310 Gas Grill
What caused my kitchen pipe to burst?
I have never heard of this in all my years of appliance repair but I would tend to think that it was a one off hose and nothing more than that.
Well, that's my two cents. :)
Nov 01, 2012 | Washing Machines
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
How can I get out of the BURST MODE with my Lumix ?
Here's one way...go into the menu and find "reset"...follow the on-screen instructions.
Jul 09, 2010 | Panasonic Cameras
The new propane tank is not sending gas to be ignited even though it is hooked up properly.
Hello.
Troubleshooting a grill isn't difficult. Close the propane outlet valve at the tank. Disconnect the tank, and get it out into the open.. Crack open the valve and make sure that you have a burst of gas pressure. (Careful here, you don't want to have a bad day. Point the opening away from you.). If you are sure that you have a good cylinder/gas and valve, it may be your regulator. Hook it back up and try for gas at each valve. Leave the lid up/open. You should be able to hear it if it is coming through one of your valves. (I should caution call here again.... Open only one valve at a time, check for sound, and close it. Wait two minutes, and try the next valve). You don't want to inadverdantly create a pocket of gas that could flash on you, if it found a source of ignition...let it dissipate, then try the next one, etc..Don't try any one valve for more than 10 seconds. If you are unsure that you heard something, please , follow the two minute rule. Should it be your regulator, replacements are readily available at "home hardware" type stores (Lowe's, H/Depot, etc.) and are easily replaced.
Hope that this was helpful to you.
Best regards --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Weber Genesis S-320 Propane Grill
Grill won't start
The regulator on the gas feed line is not working properly. Take the regulator to a propane supplier and have the regulator checked.
Apr 25, 2009 | Grilling
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Instructions for hooking up a new monitor
if you attach correctly all the connections then nothing to worry about. if you just follow all the instructions carefully and correctly then set back and relax... okay...
Dec 14, 2008 | HP W2007 LCD Monitor
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
Grilling Logo
101 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
