Question about Blomberg Dishwashers
My Blomberg dishwasher is leaking a small amount of thick, dark green liquid. Front, bottom left.
I switched from rinse agent to vinegar about 3 weeks ago.
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
SOURCE: Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
I just had this same problem and it was caused by a small plastic seal on the bottom of the door. My friend owns an appliance store and he said this is a common problem for this model of dishwasher. The part was $68 and the labor was $60. I could have easily fixed it myself if I knew what the problem was but he came out and fixed it so I had to pay the $60 for the service call.
The part number on the repair bill is 14633F. I'm not sure if that's the frigidaire part number or the one from my buddy's inventory. Anyway, hope this helps.
Also, one other word of advice........use a little less soap and it won't suds up quite as high, which will help in the mean time.
Posted on May 22, 2008
  • 11 Answers
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
SOURCE: Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Posted on Aug 18, 2009
Leaking a small amount of thick liquid out the bottom
Take off the outer door cover sounds like the dispenser leaking
Jan 28, 2015 | Dishwashers
Rinse agent (blue liquid) is leaking into the bottom of the dishwasher compartment. Every time I refill, it leaks out within a few days. Any idea what is causing this?
There is a lot of info missing like brand and model, but it a general way they all work the same. A preset amount is dispensed in the last rinse cycle by an electric circuit. Sense this appears to leak the entire amount the valve/ opening is not shutting. A repairman would just replace the rinse aid dispenser assembly. They are hard to clean because the are a molded/sealed assembly.
Dec 29, 2014 | Dishwashers
I put rinse aid in but it seems to not be working or at least it keeps showing that it is full and it doesnt go down? Also it seems that there is always detergent left in the slots after it gets done...
The rinse agent dispenser holds up to 8 ounces of rinse agent and only 2-3 small teardrop sized drops are added in the rinse cycle ,thats all it takes per cycle so a full dispenser could take 2-6 months to become empty depending on how often ya run the dishwasher.
As far as some detergent remaining,check the filter in the bottom of the tub for some blockage,if the water cant spray forcefully because its hard getting into the pump from filter blockage it cant wash that well
I hope this helps
Gene
Aug 03, 2011 | Kenmore Dishwashers
Vinegar or jet dry
both actually. Use a rinse agent (jetdry) in the dispenser and refilll and needed it dispenses about 2 tear drop sized drops on the rinse cycle, Vinegar will clean any nasty things left behind once cycle is done it can be used about every 2-3 months
Aug 03, 2011 | Bosch Integra 500 SHX55M0UC 24 in Builtin...
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishwasher not draining completely-suds left
Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Accidentally put normal dishwashing liquid in the rinse aid space
The amount you have put in although not good is not too serious.You can try putting nothing in dispenser for a few washes and see how that goes.If you are using the 3 or 4 in one tablets you should not need to dose with rinse aid or salt as it is in the tablets.
Hope that helps.
May 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I am having problems with the white scale being left on the inside of the dishwasher and I am not sure how to add the rinse agent to the despenser to stop the streaking and spotting. My model number is...
1) Do maintenence as suggested in operators manual
2) Buy 3 (yes 3) Dishwasher Magic (ACE carrys it)
3) Run all 3 - NO dishes
4) Load dishwasher with 3 cups white vinegar
5)Run cycle with Glasses only
6) NEVER USE LIQUID AGAIN - powder only!
Jul 16, 2009 | Bosch Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
Dishwashers Logo
161 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
