Question about Frigidaire Refrigerators
We recently move our frigidaire Frye m one house to another. The ice maker was working great at the old house but will not produce ice now. It has been a week. The water dispenser works.
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
Why don't my ice maker work
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, even though you have replaced the ice maker and the water valve. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the ice maker is not producing ice. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Refrigerators
Fghb2844lf1 ice machine is not work
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FGHB2844LF1, is not producing ice. I suggest turning your ice maker off and taking out the ice tray and dumping any ice that is in the tray. Wait 3-4 hours. Dry the tray out and put it back into position. Turn the ice maker back on. It will take anywhere from 2-3 hours for ice to produce. If your refrigerator is still not producing ice, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Ice maker is not working. I hear water running to ice maker but no ice is being produced
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjjhfkj
Jul 02, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice maker will not work
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kitchenaid 8-yr old fridge wanting to upgrade icemaker
Check out this site - it gives a toll-free number to call to ask for exactly what you want. Unfortunately I have not been able to find any alternative ice makers advertised or discussed, but speak direct to frigidaire and they will keep you up to date on any new products. http://frigidaire.stores.yahoo.net/
Feb 25, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
