Question about Lexmark Office Equipment & Supplies
Can anyone tell me which Samsung or Lexmark model is equivalent to the Dell C1760NW? Dell doesn't have a service manual and I need to fix a problem with toner cartridge insertion.
The receptacles where the toner cartridge nozzles are inserted are supposed to be spring loaded, but the receptacle for the black cartridge is jammed in tight and doesn't move, which results in an error that makes the printer unusable. I need to know how to safely disassemble the thing just enough to find and correct the jam, which can't be done from the cartridge compartment.
All Office
  • 58 Answers
SOURCE: Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Posted on Jun 25, 2007
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
  • 412 Answers
SOURCE: 929 service toner sensor error
Error: 929 Toner Sensor
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
Click here to order toner cartridges and other supplies for your printer.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
Muzzi_123
  • 749 Answers
SOURCE: trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
Posted on May 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Posted on Jul 23, 2009
Dell c1760 printer paper jam but don't see any paper. Can't find a place to open to inspect rollers and such. Any suggestions will be appreciated.
Hi Randy,
I am responding to your question you asked four years ago. Today I had the same issue with my Dell c1760nw printer. It would say open the rear door to remove the paper, but i couldn't see any. Using a flat screwdriver, I snapped out the 1+ inch plastic pieces (three of them) and exposed a pair of screws. Then take off the rear door and remove two other screws next to the hinges-holes for the rear door. Now you can snap up the top piece that ll you need is to lift it to expose the fuser area. You should now be able to see possible left over piece(s) of paper. Carefully remove the pieces and avoid touching the fuser. That's all to it.Putting all back together should be easy using common sense. I found a single piece of paper just above the fuser in the enclosed area. I removed that and the printer was back to normal. i hope this helps you or someone else.
Jul 30, 2013 | Dell, Inc Dell Color Printer C1760nw -...
Samsung SP47W3HF Service Manual
I know a friend selling service manual for $5, maybe he has this model. Email him edolago@yahoo.com
Feb 28, 2013 | Televison & Video
I need anyway way to get a software download for my dell v305w to print on my mac. I hear you can use Lexmark software equivalents and it is my understanding the equivalent to the v305w is Lexmark x4650....
As you correctly point out the dell printer does not have driver for mac.
I dont think having a lexmark driver will work as the printer will still say its a dell to your computer.
You may have to borrow a printer that is mac compatible or save files to windows format and print on friends computer.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Lexmark X4600 Laser Printer
Says "NO COLOR CARTRIDGE".
Try this:
According to the Dell website, this is how the cartridges for the Dell All-In-One Printer/Copier/Scanner Model AIO A940/A960 are supposed to look like. (see attachments)
Black cartridge P/N: 7Y743 with U-shaped "lump" on the (black) lid. (equivalent to Lexmark "82")
Color cartridge P/N: 7Y745 with square with corner cutout "lump" on the (blue) lid. (equivalent to Lexmark "83")
BUT, the black Dell cartridges have the identical corner cutout "lump" as their color cartridges. In other words, they have the lid from the color cartridge, but in black instead of blue.
Both cartridges are made by Lexmark and rebranded for Dell. But Dell made the black cartridge intentionally with a different "lump", so customers are forced to buy expensive Dell cartridges.
Stupid actually, because now the black and the color cartridges each fit in the other's slot!
Beat Dell at their own game, don't pay their rip-off prices!
When you open that Dell printer, lift the black lever that closes over the black cartridge. From the underside of that lever you will see a small "pin" sticking out, that corresponds with the corner cutout "lump" (as depicted on the color-cartridge). Cut that pin off with a sharp knife or a wire cutter.
All of a sudden, the cheaper Lexmark "82" black cartridges fit in (and any other remanufactured equivalent).
Money in your pocket!
May 13, 2010 | Dell A940 All-In-One InkJet Printer
Printer won't recognize brand new color cartridge
May 12, 2010 | Dell 944 All-In-One InkJet Printer
Im trying to connect a dell v305 printer to a new mac
NO Dell do NOT support Macs on there printers - BUT most of Dells printers are re-branded Lexmark engines - so if you can find the equivalent lexmark - you may find a driver lexmark makes all of dells printers the v305 or v305w is a lexmark model X4650. the Mac driver is here http://support.lexmark.com/index?page=content&productCode=LEXMARK_X4650&actp=PRODUCT&id=DR9768&segment=DOWNLOAD&userlocale=EN_US&locale=en
Apr 11, 2010 | Dell V305w All-In-One R840635AU InkJet...
Is the Dell 1710 made by lexmark? if so which model is it
Yes they are.Dell printers are made by Lexmark. The 1710 is actually a Lexmark E240 in Dell clothing - a very highly rated printer and a top pick by Buyers Lab Inc (7,000 pages without a single paper jam according to BLI). HP has a bogus comparison of the Dell 1710 with the HP 1320. HP never actually bothered to test the 1710 and based its comparison on the 1700, not the 1710. I can tell you that the 1710 first page out is 8 seconds, not the 34 seconds that HP states. Also, the HP 1320 is TWICE the price of the 1710, so the comparison itself makes no sense (and of course a $159 printer will not have duplex printing!)
Thanks!!
Nov 04, 2009 | Dell 1710 Laser Printer
Heard lexmark makes Dell printers. If so,could you tell me the equivalent Lexmark to the Dell all=in=one 964?
Dell's Photo All-In-One Printer 964 uses internals similar to the Lexmark P4350's, with corresponding inks and driver software, but adds an automatic document feeder (ADF) and color fax capabilities.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 08, 2008 | Office Equipment & Supplies
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
