Question about Onkyo Audio Players & Recorders
Onkyo TX-NR616 Receiver will not turn on. Just hear a relay clicking. Can I download the schematics for this unit?
  • Official Brand Answer
  • 333 Answers
Hello, we do not provide schematics to end users only authorized service centers. I suggest taking it to a service center. Thank you, Onkyo USA
Posted on Apr 20, 2017
Set my mac to the receiver
Hello Clifton booker, You would need to run an HDMI cable from the MAC to the receiver. Thanks, FJD
May 30, 2016 | Onkyo TX-NR616
Why cant i get sound to come out
HI
since when you have this unit ?
when did this problem started?
the more information is better so i can help you
Regards
Apr 24, 2016 | Onkyo Tx-nr616 7.2 Thx Certified Network...
I have a onkyo TX-NR616 receiver which has now for some reason has no sound when fist switched on, however if left on for about 15 minutes then turned off and straight back on again then after a few s
There is an extended warranty coverage that Onkyo is providing on receivers manufactured between 2009-12. Not sure if the TX-NR616 is included, but here is a thread from the AVS forum on the problem:
Onkyo acknowledges failed units and extending warrranties until 2018 AVS...
Feb 07, 2015 | Onkyo Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Onkyo receiver is not starting up hdmi from receiver to tv
run an HDMI cable from TV direct to DVD or other HD source instead of going through Onkyo. If it works, you have a bad HDMI output on the Onkyo. If not you may have a bad cable or a bad port on TV. Then try a different HDMI input on TV.
Jan 15, 2013 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Need Onkyo tx-nr616 remote code so ATT U-verse remote can control Onkyo
I used 5002 and it works for on/off only. This is better than nothing. You can try codes from other Onyko devices to see if you can get one that provides more functional control.
Dec 31, 2012 | Onkyo TX-SR705 Receiver
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
manual
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Dec 29, 2008 | Onkyo TX-SR602 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
52 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
