Question about Samsung Washing Machines
Samsung Energystar Silvercare front load washer received nd error code due to not draining/spinning. Replaced drain pump, Please help me reset to wash again. Thank you in advance for helping me
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
SOURCE: have samsung silvercare front load
"ND" means "Not Draining". I have the same washer, and when I get this problem, it's usually because I've tried to wash something that is causing over-sudsing (like a bath robe that was previously washed in an inefficient washing machine which left a lot of soap behind).
I find that turning the machine off, then selecting "Rinse and Spin" works. I suppose if it's a serious Not Draining problem, it could be that the drain hose is clogged somehow -- start by making sure they're not kinked.
Posted on Oct 04, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Chesc
  • 59 Answers
SOURCE: Samsung washer keeps reading ND. Have manually
The nd error code stands for No Drain.
Try following the steps here:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=4&PROD_SUB_ID=864&PROD_ID=866&AT_ID=149972
You will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced.
I hope this information helps you. A 4-thumbs up rating is greatly appreciated. :)
Posted on Jun 07, 2011
When the washer mark nd,what that mean?
SAMSUNG Silvercare Front Load Washer will not drain ...
? 3:06
www.youtube.com/watch?v=JozFGnPsQvA
May 4, 2013 - Uploaded by eallevato Troubleshooting a Samsung front load washer that is displaying ...Ordered a new pump and still no spin and "nd" code comes on after a while.
Sep 27, 2015 | Washing Machines
Getting nd code and load will not drain water after washing and will not go into spin mode. I replaced the drain pump (one vane on pump broke) but still getting the code. I checked and cleaned all hoses...
"nd" means: Your washer is not draining. It can also mean that the unit senses a small clog while draining. Before calling for service, check the following.
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
So it sounds like it knows its not draining but wants to. If you can hear the pump driving, it is a clog somewhere. If you don't hear the pump driving, it could be the pump has died.
For all you do-it-yourselfers out there, I got this information from the user manual I found at:
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06%5B1%5D.pdf
Mar 24, 2015 | Samsung WF337AA Front Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
Samsung washer keeps reading ND. Have manually drained the washer, cleaned all the hoses out. Found a coin, removed it, washed a blanket and the washer worked fine. However when doing another load, again...
Jun 07, 2011 | Samsung WF209ANW 40 cu. ft. Front Load...
I have a ND code on my samsung front load washer
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Apr 13, 2011 | Samsung WF328AA Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Nd on washer
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have samsung silvercare front loading washer....received and error code of ND what do I do?
Jul 20, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
