WJRE5550H1WW.EVERYTHING SEEMS TO WORK BUT NO AGATATION, NO SPIN....
  • 114 Answers
SOURCE: kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Posted on Jan 24, 2008
my washing machine is not rinsing and spinning
Posted on Jan 26, 2008
  • 1937 Answers
SOURCE: MODLE 80 WONT AGATATE OR SPIN
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.29852991
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Nov 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: my ge wjre5550h1ww wont spin.
Might need to be reset. To Reset the Inverter board on the motor push the timer knob in so the washer is idle or if digital have the machine in the off position. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. This might take more than one time. Service Manual and MORE HERE
Posted on Aug 23, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a 2yr old
A lot of times different problems with that type of GE Hydrowave washer can be resolved by resetting the control board on the motor. Its very simple to reset the motor board and see if that solves your trouble. This tip i wrote explains how to reset that motor control board. http://www.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Posted on Sep 12, 2011
THE agatator on my FWS777GFSO stopped working
Check to see if the belt on the bottom has broke.
Aug 13, 2012 | Washing Machines
I have a 2yr old WJRE5550H1WW that all of the sudden will not spin - it does everything else correctly just no spin action? Any ideas?
GENE
Sep 12, 2011 | GE Kitchen Ranges
My ge wjre5550h1ww wont spin. everything else work up to that point
Aug 23, 2011 | GE WBSR3140DW Top Load Washer
We have a Frigidaire FWTB59RGSO front load washer. The fast spin cycle is not working properly. The shocks on the bottom were replaced because they were broke. The problem has not gone away. It is...
I have a front loader washer # fwtb59rgso and it wont spin or agatate, everything else works fine. feels like normal drag on the drum when I try to rotate it. Any ideas what could be wrong?
Nov 28, 2009 | Frigidaire Washing Machines
AGITATOR NOT SPINNING WHEN THERE IS A LOAD IN MACHINE. IT SPINS WHEN NO LOAD IN MACHINE. (GE TOP LOADER)
Check to see if the nut on top is loose if it is tighten it up by holding the agatator with one hand then screw the cap back down, if it is still not working you will need to see if the agatator is stripped if it is you will have to buy a new agatator and you can find them at this web site. www.appliancepros.com
Nov 13, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer 80 series 4 years old
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
