Question about Amana Washing Machines
Top load washing machine damaging cloths
Amana top load washing machine, ripping and tearing cloths and even staining them sometimes
  • 923 Answers
In what way are they getting damaged, and is the machine under warranty?
Posted on Apr 18, 2017
Testimonial: "ripping and tearing them and sometimes even staining them, nothing sharp in drum"
  • james brake
    james brake Apr 18, 2017
    no this is not under warranty anymore
  • solver2010 Apr 19, 2017
    Yeah, I have seen such before. I suppose you have some sort of agitator in the washer drum. Is there any vertical play in that agitator? In other words, can you move it up and down any at all?
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Stop Kenmore 700 series top loader from ripping small holes in towels?
Look for damaged rotor, possibly small dents with sharp edges or cracked unit that catches the clothes.
Feb 17, 2015 | Kenmore Washing Machines
Washer makes stains on clothes
same thing happened in mines i put it though a hot wash with no clothes or washing powder it seemed to do the trick
Mar 16, 2012 | Maytag PAV2300 Top Load Washer
Whirlpool cabrio model WTW7340XWO ties cloths into a knot when spinning
You buy another top load high efficiency machine and load the clothes in same manner, you will get same result. No matter whether it is whirlpool or samsung or LG.
If you buy Maytag, Amana, KitchenAid, JennAir, Roper, Inglis and even sometime Kenmore. You will be buying the same Whirlpool Corporation machine with a different face plate.
hey listen your machine drum gone
Oct 09, 2017 | Whirlpool R 850 RT Washing Machines
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
Tearing clothing
Either use a more gentle cycle or the agitator may be off centered or could have bad coupler or bearings. Otherwise check the seal on top of tub to make sure it is not ripped and catching clothes
Sep 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
