Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Power surge here and had the same problem
Finally got it to drain with cancel/drain butr the normal light is blinking now and it won't change cycles, run, or do anything. When we killed the breaker for 20 min to try a reset, that didn't help either. After the door has been open a couple minutes and we shut it, the normal light stops blinking for about 2 min, then starts again.
jmiller366@yahoo.com
  • 36 Answers
Sounds like a bad door latch.the unit thinks the door is open
Posted on Jul 24, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
My Status light is blinking, red orange, green and It won't stop
This just happened to me! I found this fixya and it didn't help me. So I checked the status of the printer and it was trying to print some 3,000 envelopes, OOPS!!! Needless to say I cancelled the job but it still had to go through all of the pages before cancelling and finally stopped blinking!
Jul 18, 2012 | Brother HL-5370DW Duplex Wireless Laser...
Whirlpool Quiet Partner II dishwasher won't run after power went out. How do I reset it?
I hope it's still in warranty. Usually when power comes back on after a power failure, there is a power surge that takes out electronics.Sad, but true.
Sep 29, 2017 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
234 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
