Turned off t.v. with remote. Now t.v. won't come on with remote or push button power on set. HELP!!!!
4 Suggested Answers
maatmartin7
  • 1216 Answers
SOURCE: My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Posted on Sep 25, 2009
SOURCE: Start button blinks; won't empty; won't leave wash cycle
turn your dailer to spin cycle
Posted on May 21, 2012
dduncan774
  • 760 Answers
SOURCE: Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Posted on Aug 23, 2012
I turned off my tv last night with the remote and now it wont turn it back on help
check to see if top of remote has settings like,aa&t tv, power, dvd,aux. try pushing one at a time, then power. you may have just hit another button accidentally.
Apr 03, 2015 | Televison & Video
Intelligent Sensor
Make sure intelligent sensor is turned off, by pushing green button on remote untill you are on the right choice "off". also make sure picture setting is on "standard" not cinema, expert or any other setting These buttons are sometimes near the power button and easily pushed by mistake.
Feb 16, 2014 | LG Televison & Video
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept book..here it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Don't have remote. T.V won't turn on, but power light is on
well try to push buttons on the tv , i belive that might help. for example i had the similar problem and i just pushed the AV/TV button and it turned on. good luck
Jan 05, 2010 | RCA TruFlat 27F520T 27" TV
Activities button won't work
Have you tried the "help" button? That usually rights anything wrong with the unit, by itself.
If not, connect it to a PC, and let it re-program itself.
Jan 27, 2009 | Logitech Harmony One Advanced Universal...
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
