Question about Kitchen Ranges
Model KSGB900ESS error code F2E0. Is there a procedure for removing error
  • 5,380 Answers
This error on a Kitchenaid range indicates a problem with the keypad communicating with the main control unit. This can be caused by a wiring problem, a faulty keypad or a problem with the main control. The usual solution is to check the wiring and then replace the keypad if the wiring is fine. Replace the main control if the new keypad doesn't solve the issue. Note: some models only sell the keypad and main control unit as a single assembly.
However, you seem to be missing a digit from the end of the model number. See http://www.appliancepartspros.com/search.aspx?model=ksgb900ess to see the two models. Some parts for the KSGB900ESS1 are here: http://www.searspartsdirect.com/model-number/ksgb900ess1/0593/0124250.html . See the cooktop parts list and look at part 3.
I hope this helps.
Posted on Apr 18, 2017
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
Error display f2e0
What is the make and model number of your unit?
Sf367lxss 2 turns off during preheat
F2 E0 is certainly a the error for a stuck key on the pad. Did you buy a new? If so you need to return it and have it replaced. Here is the part to order.
Feb 09, 2013 | Whirlpool GR773LXSS - Stainless Steel...
I am getting an error code f2eo and it is saying stuck key. No button will work.
Error code f2e0 means the touchpad is bad. Give me the part number, or go to ApplianceTimers.com, we may be able to repair it.
Mar 20, 2011 | Kitchen Ranges
Error reads F2E0? Can anyone tell me what this means?
Need model off range . Pull out the drawer and is on the side of opening
Nov 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
What does error code F2E0 mean?
Hi
Thanks for using FixYa. Error F2-E0 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 25, 2010 | KitchenAid Kitchen Ranges
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
