Question about Stainless Coffee Makers & Espresso Machines
How do I fix the right side of my espresso machine so that it will pull shots correctly? The water isn't coming out as much as it usually does therefore the shots are not full bodied.
I tried taking apart the machine to clean it by taking the stainless steel filter off and cleaning it and back flushing the machine, and it still does not seem to be pulling a shot correctly. The shots are pulling slowly and they are a dark black, even though they have the correct volume.
SOURCE: Problem with espresso - no water to the brew head
We just bought the unit today before researching the product online. Same problem! Will try to return tomorrow.
Posted on Jun 26, 2008
SOURCE: Astra Mega II <----Need help!
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Posted on Sep 13, 2008
SOURCE: cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Posted on Sep 17, 2008
SOURCE: starbucks barista won't pull a shot
go to this link - read the whole thing - hopefully it will fix yours.
http://www.fixya.com/support/t662074-saeco_italia_sup021_yr_red_light_29
Posted on Oct 27, 2008
  • 7 Answers
SOURCE: My Breville800ESXL makes steam but does not make espresso.
jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Posted on Dec 02, 2008
KitchenAid Pro Line espresso machine leaking water onto counter after repeated shots
I keep hearing how this machine makes great crema but I'm about ready to toss my machine in the dump. It seems like the water comes out way too fast no matter how I work the grinds or tamp it. Can someone contact me about what might be wrong?
Dec 26, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our...
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
May 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Trying to self-prime like the directions say. Water is coming out extremely slow. How long should it take to fill cup? The steam wand seems to work perfect with plenty of water coming out.
Hi
If you are doing it right and using the double shot filter basket, with the correct amount of coffee, with the right grind and tamp. You should not get anything, for about 5 seconds after you turn the pump on, and it should take between 25 and 35 seconds for an 1 1/2 oz to 2 oz of espresso.
Aug 03, 2009 | Gaggia Baby Espresso Machine
Automatic astra II pulls a few great shots then error light on
The error light usually comes on when there is no water flow through the group after about 5 - 10 seconds, indicating a clog of some sort. The fact that it happens after two shots, however could indicate an issue with the processor. The problem with the steam wand could also point to a clog situation, especially in the other wand is working. First, try running shots through the problem group with no grounds at all in the portafilter; Say five or six shots if you can to see if you get the error light. Look at the water flow in the process: The water should just pour out of the portafilter. If the water is running freely and you still get the error light, you are probably looking at a processor/sensor problem. If not, it may just be a restriction. Remove the screw from the middle of the group head (the diffuser), and remove the screen and the brass plate and check them for clogging. You really want to wait until the machine is cold before you do so as the parts will be extremely hot. As for the wand, try removing it, and check it for obstruction.
Nov 24, 2008 | Astra Mega II Espresso Machine
Apr 28, 2008 | Astra Mega II Espresso Machine
Water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Oct 13, 2007 | Astra Mega II Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Stainless Coffee Makers & Espresso Machines Experts
Vernon Taylor
ray gallant
Tom Chichester
Are you a Stainless Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
