I have horizontal lines with the crack underneath the protective screen. If you could tell me the parts name I would need it I greatly appreciate it. And thank you Tom
hardrocko
  • 1476 Answers
SOURCE: Need parts!!!!
Try this website http://www.grillparts.com/fiesta/ Good luck.
Posted on Jul 21, 2006
  • 1694 Answers
SOURCE: Horizontal Line
A LINE left / right thru the middle ( horiz line) indicates a problem in the vertical circuit.First step is to solder the pins of vertical o/p
IC.........Next, troubleshoot vertical circuit to look for problem...T.
Please rate solution................................
Posted on Nov 15, 2007
SOURCE: tom tom go 720 screen problems
You can get the replacement screen for several Tomtom models here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20para%20GPS%22
Posted on May 23, 2008
welcomejee
  • 10594 Answers
SOURCE: horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Posted on Apr 09, 2009
SOURCE: Horizontal Black Line on Plasma Screen
what is a PDP panel?
Posted on May 12, 2009
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Mar 30, 2008 | Zenith Z32H41D TV
Cracked LCD Screen
check ebay online for parts. the problem with a cracked screen is that to get it new, it cost too much. sometimes i find tv's that don't work but have good screens on ebay and you can pick them up cheap. good luck.
david
May 25, 2009 | Vizio VO42L 42 in. LCD TV
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Black display with a horizontal white line in the middle.
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to http://www.nesda.com/locator/state_search.php and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Bill
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Cracked protective screen
Would buying Plexiglas and cutting to fit work? no
you could buy a used one try craiglist.com
Mar 17, 2008 | Samsung HCL4715W 47" Rear Projection...
Problem with 480i
 This problem has been around for awhile.
 The 2HDW PCB needs to be replaced. Part number 935C966001. It sits on the signal board underneath a metal shield.
 Not a bad repair and remember to unplug the set if you are going to do it yourself.
 Respond to this post if you have any questions and I will reply.
Oct 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Flickering horizontal lines
sounds like a problem in the horizontal deflection circuit.possibly a solder problem. try re-soldering the horizontal transistor, line coils and yoke pins.
Sep 01, 2006 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
