Question about Husqvarna Garden
I have a Husqvarna self-propelled mower. This week, when I tried to start it, the cord came halfway out, then stopped with a metallic clank, though it retracts/moves easily. Any simple suggestions?
    Visited the website for 20 consecutive days.
  • Husqvarna Expert
  • 141 Answers
You will have to remove the starter, the spring may have broken, tis may be a job for a dealer as the spring can jump out of the cover when the pulley is removed.
Posted on Aug 20, 2017
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
  • 3600 Answers
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Posted on Jul 16, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
  • 1545 Answers
SOURCE: pull cord will not retract
This takes some mechanical skill and knowledge to fix...definitely would take it back..I would have thought these manufacturers could have fixed these idiotic quality control problems by goes on and on and....I know, folks would say..ya get what ya pay in this case, you paid for a useless machine that you never even were able to use...that is NOT what you were SUPPOSED to get now was it!
Posted on Jul 16, 2010
Looking for repair manual for husqvarna 175cc 22 in self propelled rear wheel
Search by engine model #. If not engine problem search by mower model #+parts.
Jun 12, 2016 | Husqvarna Garden
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Husqvarna self propelled lawn mower
Fuel problem. Disconnect fuel line from carb. No fuel, go up the line. Filter, open line, plugged fuel cap vent.
Jun 26, 2013 | Garden
I have a husqvarna self-propelled lawn mower/keystart with leaf bag. i hit a small tree root and now it wont start. the cord back fires a little when you pull it. will a bent blade stop it from cranking?
Hi hardister2...
Sounds like you sheared the key that holds the flywheel to the crankshaft, this is a common occurance when you hit something hard with the mower running.
You will have to remove the flywheel to replace the key.
No a bent blade will not stop the mower from running,but should always be replaced
It can cause problems later with the seal under the mower, it will start to leak oil.
Please take time to rate me
Jun 28, 2011 | Husqvarna Garden
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
