Question about Remington Optics
I have a remington 7mm rifle, 371831 deer hunting rifle. How old is this/
night71
  • 328 Answers
SOURCE: cross hairs are tilted to right while scope is straight
Without seeing the rifle, my guess would be that either the rings were not tight enough or the lens came loose from the shot. It is rare depending on the quality of the scope. If the lens itself moved, it will not be waterproof or fog proof because the seal on the lens is not tight. If its under warranty then it should be replaced, if not then be care full not to get it too wet. If you had a suction cup, you could try to reposition it straight again.
Posted on Nov 28, 2008
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
  • 11 Answers
SOURCE: remington #5 rolling block cal. 7mm serial number
lol
Posted on Dec 19, 2009
agent91
  • 2100 Answers
SOURCE: How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
Posted on Mar 03, 2010
  • 179 Answers
SOURCE: I took my 4x12 Redfield rifle scope off my 222
check the rings...number one problem when scoped wont stay on zero.
Posted on Jan 22, 2011
What is the manufacture date and approximate worth of a Remington model 6 22 caliber rifle. Model number on stock is S363171
he Model 6 Rolling block was made from 1901 to 1933.
rifles manufactured after 1921 will have a date code consisting of 2 letters stamped on the left side of the barrel near the receiver.
rifles made between 1901 and 1921, ask a question about the serial number of your rifle on the... Remington Society Forum to get a date of manufacture.
Remington serial number records are not publically available to determine a date of manufacture some old gunsmiths have the info but are not publishing it publically ie the internet.
prices seem to be low 395 high 795
Jan 27, 2018 | The Optics
44 magnum bullets for deer hunting rifle
Actually called 'ammunition'. On the barrel, near the muzzle, it will tell you the exact round as there are a number of 44 Mag rounds. Here are some of them for sale. There are images in the main link and one is called Buffalo Bore, Deer Grenade which is a hollow point round at 240 grains.
https://www.google.ca/search?q=44+magnum+ammunition&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=622&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwj-yOu-8sTPAhUHyj4KHYUQCP4Q_AUIBigB
44 Magnum Ammo ' Bulk .44 Mag Ammunition For Sale Cheap
www.luckygunner.com/handgun/44-magnum-ammo
  1. Cached
  2. Similar
44 Mag - 180 Grain JSP - Remington UMC - 500 Rounds. ... 44 Mag - 240 gr JHP - Blazer - 1000 Rounds. ... 44 Mag - 180 Grain JSP - Remington UMC - 50 Rounds.
44 Remington Magnum Ammo - Sportsman's Guide
www.sportsmansguide.com > Ammo & Shooting > Handgun Ammo
  1. Cached
  2. Similar
The Guide is your source for all things ammo. We have a great supply of .44 Remington Magnum Ammo at the best prices around! Check out our .44 Soft Point ...
Bulk .44 Mag Ammo Online at BulkAmmo.com - Ready to Ship!
www.bulkammo.com/handgun/bulk-.44-mag-ammo
  1. Cached
  2. Similar
Items 1 - 16 of 42 - 500 Rounds of .44 Mag Ammo by Remington - 180gr JSP. ... 1000 Rounds of .44 Mag Ammo by Blazer - 240gr JHP. ... 50 Rounds of .44 Mag Ammo by Remington UMC - 180gr JSP.
44 Remington Magnum- MidwayUSA
https://www.midwayusa.com/44-remington-magnum/br?cid=22546
  1. Cached
  2. Similar
Hornady LEVERevolution Ammunition 44 Remington Magnum 225 Grain Flex Tip ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat ...
https://www.midwayusa.com/44-remington-magnum/br?cid=21830
  1. Cached
  2. Similar
Magtech Sport Ammunition 44 Remington Magnum 240 Grain ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat Nose Gas Check ...
.44 Remington Magnum Ammo - .44 Rem Mag Bullets
https://www.cheaperthandirt.com/category/ammunition/.../44-remington-magnum.do
  1. Cached
  2. Similar
Look no further for your .44 Remington Magnum ammo! We have all the best brands for your firearm at the best prices, ready to ship right to your door!
44 Magnum & 44 Special : SFRC, your online ammo source!
www.theammosource.com/index.php?main_page=index&cPath=1_108_150
  1. Cached
  2. Similar
Products 1 - 10 of 19 - SFRC : 44 Magnum & 44 Special - Ammunition Firearms Firearms Accessories Reloading Supplies Scopes, Optics, Binos and Sights ...
.44 Magnum - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/.44_Magnum
  1. Cached
  2. Similar
The .44 Remington Magnum, or simply .44 Magnum (10.9×33mmR), and frequently .44 Mag, ... When loaded to its maximum and with heavy, deeply penetrating bullets, the .44 Magnum cartridge is suitable for short-range hunting of all North ... Bullet diameter‎: ‎429 in (10.9 mm) Rim diameter‎: ‎514 in (13.1 mm) Case length‎: ‎1.285 in (32.6 mm) Base diameter‎: ‎457 in (11.6 mm)
44 Mag - Hornady
www.hornady.com/store/44-Mag-c-354
  1. Cached
  2. Similar
... web browser. Home » Ammunition » Handgun » Choose by Caliber » 44 Mag ... 44 Mag 200 gr XTP® See details ... 44 Mag 225 gr FTX® LEVERevolution® ...
44 magnum ammunition Google Search
Oct 06, 2016 | Optics
Does a Simmons model 533940 work on a 7mm Remington
Any scope will work on any gun. Its effectiveness requires your to match capability with need. A rimfire scope is intended for a 50 yard zero. If you expect to do most of your shooting at 50 yards, it will work fine.
Nov 09, 2013 | Simmons Protarget Rimfire Rifle Scope 3-9x...
What should I zero my scope at when shooting my 7mm savage with 175g remmington core-locts?
Depends on how far you intend to shoot. Most zero their rifles at 100 yards, but if you intend to hunt plains game, you might want to use 200 or so.
Oct 15, 2013 | Pentax 4x-12x40mm Gameseeker Rifle Scope,...
How much is a remington 7mm model 700 serial #6246191 worth?
No way to tell with such a general post. Would have to see the rifle and know what grade it is ie. ADL, BDL ect. and is it a 7X57 or 7m/m express or a 7m/m Rem. Mag. The Blue Book of Gun Values is a great reference guide.
Jul 02, 2012 | Optics
Optics Logo
Top Remington Optics Experts
ray gallant
rhodesworks
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Remington Optic Expert? Answer questions, earn points and help others
