Question about Sharp Televison & Video
Sharp TV technical problems model LC-42D72U?
TV would be on for 30-60 mins and turn off and then come back on. Did this for several times. Did some investigating and found it could be the power supply board. Replaced the board and problem is still happening but not as frequent. Backlight converter? or ? and if converter which one the master or slave? Thanks David
rlamkin
  • 44 Answers
SOURCE: Replacing backlight inverter board
Not always but usually the inverter board is part of the display panel, way to much money to bother fixin.
Posted on Jul 03, 2008
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
johex
  • 75 Answers
SOURCE: Is there a common power issue with Magnavox Model 42MF337B
u have the main switching power supply unit blown. fuse will immediately blow as u have mentioned. they all use smps (switched mode power supply system).  it may be concealed under aluminium plates or cover. look for a  transformer with yellow insulation tape covering near the ac mains input. it is a high frequency tranformer with solid ferrite core. near it there should be the main switching section with a heat sink attached.
Posted on Apr 13, 2010
electrotech1
  • 1126 Answers
SOURCE: Tv works if the backlight stay min. but pickture
It is the power supply and if you replace the bad or bulged electrolytic caps on the power supply, or you can buy a new power supply at www.partstore.com.
Posted on Dec 21, 2010
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Sharp LC 26sh20u picture problem
There are several capacitors on the main board and the power supply that can go bad with age. There are repair kits available that address this problem. Go to www.shopjimmy.com to see what's available. TV Parts DLP TV Lamps TV Repair ShopJimmy
Jan 14, 2014 | Televison & Video
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on sharp tv flat screen model LC when turning on again
we fixed the problem, no further assistance required
Thanks
Feb 16, 2010 | Sharp Televison & Video
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
The firmware do not finish.. just turn off and
Unplug the ac power cord from the wall for 30 seconds then hold down the power button on the tv, not the remote, and while holding down the power button plug the ac powercord back in and continue holding the power button untill the tv turns on. This is a hard reset back to factory defaults.
Nov 24, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Picture Blacks Out, Sounds Stays On
I spoke to several representatives from Sharp and ultimately they are sending a repair person to take care of this problem at no charge. They realize that this is a problem enountered by several people who own this TV. Hopefully, the repair service will be here in the next day or two.
Sep 29, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
