Question about LG Rumor LX260 Cellular Phone
My cell phone won't charge or respond to the charger at all. I have tried taking the battery out and plugging it into different outlets, but nothing helps.
    Problem Solver:
  • 12 Answers
Ask sprint about new charger
Posted on Aug 02, 2009
How can I retrieve contact numbers from my fone that has discharged and wont charge
My phone died and now won't power on or charge. Here's how to fix it. Did your mobile phones battery drain all the way to zero and now your device is completely dead, not powering on or not even letting you charge it? This article will go through some tips on how you might be able to revive your dead phone.
If your cell phone is a smartphone then this is a reasonably common issue. It used to be a general practice to run older batteries to zero battery life before charging them back up to full again but try not to do that on the new smart phones, they use lithium-ion batteries which discharging 100% is a major concern and isn't good for the health of the battery.
If your battery has drained to zero and now the phone won't respond then try this
Pull the battery Start out by pulling the battery out of the phone for a few minutes then put the battery back into the phone, put the phone all back together and then plug it into your ORIGINAL charger that came with the phone. Make sure that you use the original charger that came with the phone. If you don't have the original charger then make sure that your charger is a manufacturer approved charger. If your battery is built into the phone and you cannot remove the battery from your smartphone then try to perform a simulated battery pull. Many phones have a method to restart the device, usually by holding down specific buttons or keys on the device. Much like the Motorola Atrix HD simulated battery pull or the Sony Experia simulated battery pull where you hold the volume down key and power key simultaneously while the phone is powered off.
Check the outlet Sometimes we can be too close to an issue and can overlook something as simple as a wall outlet attached to a light switch that's turned off. If the light switch is designed for turning off and on a light and the switch is off then there is no power coming from the outlet and obviously your device isn't going to charge.
Try a different outlet This can go hand in hand with the above suggestion. Try a different outlet to make sure it's not a power socket issue.
Try using a computer or car charger Using a computer or car charger instead of a wall charger can sometimes put a quick charge on your battery and get it to respond as well. Keep charging it If you have tried these methods and your phone isn't responsive due to its battery being drained 100% then it can be difficult to get your phone to charge again. Try charging it for at LEAST a couple hours on an outlet you know to be working, even all night if possible. Lithium ion batteries can take a while to get to charge again if drained all the way. So try charging it for a while, You might need a new battery If you try these tips and suggestions or have tried all these things already and there is still no response, and your phone is completely dead and will not recognize a charger then you might need to try another battery.
Try a different charger If you have tried a different battery then make sure you try your original charger first, as mentioned above. If there is no response then it might not be your battery but your charger that has malfunctioned and might need replacing. If you have any spare chargers try those to see if you can get a charge out of your phone. Replace the device If you have tried a different battery and a different charger and your phone is still little more than a paper weight then you should start reviewing your phone replacement
Sep 30, 2016 | Cell Phones
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
Lg 840g manual
try a new battery in the phone if that does not work you will after try a different charger or get the charger port fixing
Mar 08, 2018 | Cell Phones
My phone wont power on EVEN WHEN PLUGGED IN. please send me a list of nearby service centers so they can see im not crazy and exactly what my phone is not doing since maybe part of the problem is i ca
The most common reason a phone won't power on is when the battery is completely dead and a wall charger, not plugged into a computer, is the only way to get it to charge. If plugging it into a wall get's you nothing, then you can try and remove the battery for 10-20 seconds or hold the power button down for 20 seconds to hard reset the device. I would also try purchasing a new charger or take it to your service providers stores and have them try a different charger. Your local providers stores also have repair services if nothing else works.
Nov 23, 2013 | Kyocera Jax Cell Phone
My ZTE Merit Will Not Charge
go to amazon and obtain a ac/usb desktop charger.. it is an external charger.. you have to charge battery outside of phone.. most kits come with 2 batteries however it your choice.. OR YOU CAN JUST TRY TO BUY ANOTHER PHONE..
Aug 10, 2012 | ZTE Cell Phones
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but...
i think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargermoz-screenshot.png7bf4754.jpeg
Apr 13, 2010 | Motorola Mobility W376 Cell Phone
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
Power on Problems
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Sep 18, 2008 | Motorola Mobility RAZR V3
LG Rumor LX260 Cellular Phone Logo
191 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
