Question about Samsung Microwave Ovens
How do I replace the control board on a Samsung SMH9207ST
    Master:
  • Samsung Master
  • 923 Answers
How to reset an error code of SE on a samsung microwave model SMH9207ST
May 24, 2017 - SMH9207ST
There's no reset for it, but you can find the two solutions on my page here: http://www.microwavecontrol.com/samsung_se_error.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Apr 19, 2017 | Samsung Microwave Ovens
Samsung microwave smh9207 SE Error, there is no ribbon wire on circuit board.
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Nov 16, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
No power to unit replaced thermostat , door switches, diode on capacitor but not the two fuses continuity goes to 0
There are 2 thermostats or "thermal fuses" in it that would cause no power. One is on the magnetron, the other is above the microwave cavity near the middle. Have you checked/replaced both? You should have 120 volts between the white wire on the main relay on the circuit board & the black wire in the smaller connector on the board. If you do, bad board, if not, something before the board (fuses, thermostats, noise filter board, etc). Door switches, diode, capacitor would not cause no power to unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jun 03, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
How to replace the control panel on a Samsung smh9207st microwave oven
Apr 25, 2015 | Samsung Microwave Ovens
How to replace a the control board on a Samsung microwave
Apr 25, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
How do i replace smh9207st buttons
If you mean the 4 silver buttons on the lower right of the unit controlling the lite and fan, then see the instructions below...However, if you mean the control panel buttons in the door surrounding the clock display, then you and I are in the same boat. But I digress...
0. UNPLUG THE UNIT
1. Remove the grill atop the unit, 2 phillips screws. Gently slide the grill to the left to unhook it from the unit. This reveals the screw holding the right side cover.
2. Remove the screw holding the cover in place; you can now pull it away from the unit. You must disconnect the wires/plugs from the back. Take a photo for reference. One plug will remain: this belongs to the buttons in question.
3. Set it on a soft cloth to prevent scratching. Remove the screws holding the circuit board in place and the remaining plug; remove the board, then remove the metal tray/box underneath the board.
4. The PCB with the buttons is now visible. There are tabs holding it in place; gently pry them off and the board, a thin plastic shield and the buttons should come free.
Now you can clean/replace the buttons and/or the membrane buttons. Reassemble in reverse.
Cleaning tip: Scrubbing bubbles works great for cleaning icky kitchen grease, although it can leave a film (but it gets the grease!). Follow up with windex (but use a windex-dampened paper towel on plastic to prevent scratching)
Jun 24, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
Samsung SMH9207st brand new, clock will not keep the correct time (loses time). How can I fix this w/o removing the unit?
You can't. The clock is crystal controlled at 32kHz and the crystal is obviously out of spec.
Get a new unit or control panel whilst under warranty and free of charge.
Hope that helps
Dec 11, 2010 | Samsung Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
