Question about Maytag Washing Machines
How to tighten the belt of a Maytag washer model SAV365AAWW? In fact, the spin cycle is not working. The rest of the cycles are working fine.
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
GodBlessU
  • 3513 Answers
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Posted on Aug 11, 2009
SOURCE: Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Posted on Feb 27, 2010
How to tighten the belt of Maytag washer model SAV365AAWW?
Depends how good you are with disassembly. It's not that difficult and you need to shut off the water and unplug the machine. The front needs to be removed and on the bottom is where the belts are. Loosening the pump retention screws and pulling the pump towards you while you tighten at least 1 not to hold the tension. Then tighten the other screws on the pump and reverse disassembly order. Too tight on the belt will burn your pump up and of course too loose will allow them to slip. I would look and see why the belts are slipping. Water leaks, worn out? For the proper tension, on the center of the belts, you should be able to press your index finger on it and it will push in about 1/2". Good luck
Apr 18, 2017 | Maytag Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
Washer will not drain on spin cycle, water stays in machine
you might have a broken pump belt go to www.repairclinic.com enter model number and scroll down to the red 100 click it and start looking for the pump part number 1480330. You'll have to lean this thing back far enough to see if it is your belt or maybe even go through the back of it.
Mar 22, 2009 | Maytag LSE7806A Top Load Stacked...
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
