Question about Maytag Washing Machines
How to tighten the belt of Maytag washer model SAV365AAWW?
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hello Alexander, we'd be happy to help you arrange service as we are not trained technicians and would be unable to instruct on tighten of he belt. If you still need assistance, please provide your name, the name of the site you were contacted on (fixya.com), your user ID name (Alexander Sitth ), your phone number, your address, the full model and serial number, and email the requested information to Maytag_Digital@Maytag.com. We would be happy to review your concerns further.
    Master:
  • 347 Answers
Depends how good you are with disassembly. It's not that difficult and you need to shut off the water and unplug the machine. The front needs to be removed and on the bottom is where the belts are. Loosening the pump retention screws and pulling the pump towards you while you tighten at least 1 not to hold the tension. Then tighten the other screws on the pump and reverse disassembly order. Too tight on the belt will burn your pump up and of course too loose will allow them to slip. I would look and see why the belts are slipping. Water leaks, worn out? For the proper tension, on the center of the belts, you should be able to press your index finger on it and it will push in about 1/2". Good luck
Posted on Apr 18, 2017
My washer won't agitage on my maytag washer model fav6800aww. first started with a squeaking noise
Move the motor or pulley out of the way a bit and remove the old belt and replace with new, unstretched belt, tighten the motor or pulley and that is it.
Nov 14, 2015 | Maytag Washing Machines
On my washer the belt come off
You will need to use a socket set to loosen the belt tension bolt. Then place the belt over the drive wheels.
Now tighten the belt tensioning bolt, while applying force to the belt to tighten it around the drive wheels.
take care!
damnor01
Apr 28, 2012 | Maytag Washing Machines
AMANA WASHER MODEL # LWA40AW2. HOW DO I GET TO THE DRIVE BELT TO TIGHTEN IT?
Top loader so the belt is on the bottom of the washer, should be able to turn it over and take a panel off.
May 02, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Tightening the motor for the belt tension
the glides on the motor do it change tem
Apr 20, 2010 | Maytag PAV2300 Top Load Washer
Tighten motor belt on maytag washer
you don;t!! you have to change them when there stretched out
Jan 19, 2010 | Washing Machines
Maytag stacked washer/dryer fills with water, makes noise like it's working, but won't agitate, but at the end of it's cycle pumps out but won't spin either. Is this a belt problem? If so how hard is it to...
Definately sounds like the belt is off. Not too big of a problem for small hands mechanics. Usual problem lately with Maytag is the spindle pulley. For some reason they haven't been tightened properly and the pulley and belts are falling off. Pull it out from the wall remove the panel and see what you've got, really simple on the bottom end. Complicated stuff is up in the control panel. Make sure you get the pulleys lined up as close to level as you can or the belt will jump off on you during spin cycles. Good Luck!
May 10, 2009 | Maytag LSE7806A Top Load Stacked...
How do you tighten the belt on magtag washer
Hello sunny31,
If you believe the belt is slipping then the belt will need to be removed and replaced. There aren't any belt tensioners in your washer.. Can you provide the specific model # with a response so I can provide you with more information on how to resolve your problem?
Regards,
Rick
Dec 13, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
