Question about Electrical Supplies
I DON'T HAVE A SWITCH I HAVE TWO RED WIRES GOING TO A CONNECTOR
    Master:
  • 347 Answers
What are you looking for Donna?
Posted on Apr 18, 2017
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
How to wire a toggle switch for non working horn
My suggestion ask that mechanic to do it for you on the side maybe and see how much he would charge if you don't know anything much about going under the hood that would be best, if not here goes. First find the horn make sure you can get to it there should be a connector or plug on it should being the key word. Find it and remove it, you will need a wire long enough to run from the horn around and through some place in the firewall next to the wall between the engine and inside and back out to the battery so make sure its long enough to do that as well make sure the wire is 2 different colors inside sometimes they come copper on one side and silver color on the other or you can find black and red coated wires an 18 gauge speaker wire should work 15 to 20 ft should be plenty tape the ends of the wires with 8 inches excess hanging to the battery one end and the other to the horn not connected just so it holds the wire while you run it to inside the car string the wire around under the hood so its not all over the engine but around it and not on anything that gets hot to melt it. Make sure you know when you run it inside which side of the bend (you will have to bend it to get it inside the cab) make sure you know which side was going to the battery and which to the horn when you have the wire inside the car cut the wire on the copper side or the red side but dont cut the black shave back the plastic on the cut wire so you can get to the bare wire on the toggle switch any kind with 2 connectors on it is ok or you can also get a push button kind so it works like the horn find the positive connector on it and negative connector, connect the side of the red/copper wire that is going to the battery to the positive side if it has no positive or neg it doesn't matter either side then. Now connect the other side of the spliced wire to the negative or other side of the switch. once this is done under the hood look for positive and negative on the horn strip wire ends so you can get to bare wire connect the red/copper to the pos. and black/silver to the neg. You can use connectors for this or you can twist the wires around the connectors like a twist tie and tape with black electrical tape not clear tape. then on the battery put the red to pos. and black to neg. I would splice off enough plastic coating to wrap wire around battery terminal connector not the post make sure you connect the pos. last and don't touch the neg wire to anything else. then test the horn if it is working unhook the pos. side of the wire on the battery until you get ready for inspection and when done remove this so you don't have battery drain or other problems. Good luck
Nov 29, 2011 | Pontiac Sunfire Cars & Trucks
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
I have 3 power wires on my Jensen MCD5080 marine am/fm/cd, a +12dc switched (acc)red wire , dimmer orange wire and a +12v dc battery (constant batteryemory yellow wire) do i hook them all to the same power...
The yellow wire (constant) is for functions such as clocks, retaining fm stations, etc. The red wire (DC power) is what runs the unit. You said this is going on a golf cart right? But you say you don't want switches and don't want it to drain the battery during storage. Well, you can't have the best of both worlds. If you don't like the visual of a switch in the open, at least put one close to the battery under the seat. That way you can switch it off in storage. The switch would go to the red wire. You might even think about switching the orange wire if you expect to keep it in long term storage. the dimmer wire usually hooks to interior light controls. Like when you turn your lights on to drive at night, the radio won't be so bright inside, but in the day time, it will be. This is not a necessity. Happy wiring
Aug 15, 2011 | Car Audio & Video
I am replacing a two way switch with a two way Trimatron dimmer 6681 The dimmer has 1 black wire hot, 2 red wires and a ground (green) The box has 2 black, 1 red and 2 white What do you connect...
The best thing you can do in that situation is match the wire colors of the dimmer to the colors of the screw terminals on the switch you removed. Unfortunately, its too late for that - so here's my best guess: One of the black wires in the box will be coming from the same romex cable as the red wire. Take THAT black box wire and connect it to one of the red wires on the dimmer. Take the red box wire and connect it to the remaining red wire on the dimmer. Connect the black dimmer wire to the remaining black wire in the box. The two white connectors in the box get tied together - they don't get tied to the dimmer. And the ground (green) wire on the dimmer just connects to the bare ground connection in the box itself - or to the metal backbox - or cut it off and don't use it.
Jul 15, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Need of wiring diagram for driver's side window switches, or description of wires (colors) and placement on switches, on an 85 Carrera Thanks
Hello there
if you are replacing the switches the colors are as this
tho bottom conectors--red left-brown right-
The red is also goin to the t top connector
middle connectors --blue-black left--- blue-white right
top connector is only one and it is red (an extension from bottom red wire)
this should help you
trubka@yahoo.com
trubka
Oct 28, 2010 | 1984 Porsche 911
1995 Isuzu Rodeo 4X4 3.2 5 speed manual, reverse lights on in 1st
the wiring on the gear box is connected to switches wrong, there bullet head connectors red to red wiring and blue to blue from switch to loom is correct
both wires on one switch are red connect these to the 2 red wires one has colour trace on it also. the other switch blue wires to blue wire on loom with possibly another colour wire but they are together. you cant go wrong the connectors are male on one wire and female on the other on each switch(detent switch)
Nov 22, 2009 | Isuzu Rodeo Cars & Trucks
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
