Question about The Office Equipment & Supplies
What is the dimension of a picture that is 163 square inches
    Top Expert:
  • The Master
  • 78,267 Answers
LxWxH
Posted on Apr 18, 2017
WHAT DIMENSION OF PHOTOS SHOULD BE USED FOR SLIDE SHOW AND FORMAT JPG OR BMP??
how much quality do you want and if photo is small to start with and you are scanning it you will need 600 dpi or more where as a larger photo can use less 300 DPi as it is not being enlarged onto the screen / slide show
depends on what you intend storing the pictures on . BMP will take up a lot more memory than jpeg files. The dimension more refers to dots per square inch when scanning a photo .
Feb 22, 2018 | Computers & Internet
How many linear feet is in 18square feet
You would need the dimensions of the item that you are trying to calculate the distance on. For example, a 12 inch by 12 inch tile is one square foot. 18 of them would be 18 square feet. If you place them end-to-end you would have 18 linear feet. However, if you had a 6 inch by 12 inch tile, it would take 36 of them to get 18 square feet. If you lined the tiles up in a row on the 6 inch side, you would have 18 linear feet. If you lined them up on the 12 inch side, you would have 36 linear feet. Linear feet does not take into account width, only length. So trying to translate a 2-dimensional value into a 1-dimensional value is difficult if not impossible without more details.
See this answer as well....
How many linear feet are there per square foot
Mar 07, 2016 | Office Equipment & Supplies
51 inches tall and 12 inches wide. What is that in linear ft.
A total of 63 linear inches is 5 ft 3 in, or 5.25 linear ft.
Dec 03, 2015 | Office Equipment & Supplies
How do I get the square footage of concrete sidewalk
  • Hi Tony: Don't know what this has to do with air conditioners but .......
  • Square footage is the mathematical result when you multiply length by width.
  • Since you're trying to find square feet. the dimensions that you are using must be in feet.
  • Length (feet plus (inches divided by 12))
  • times
  • Width (feet plus (inches divided by 12))
  • equals
  • square Feet.
  • Any questions or numbers for your project? Just reply as a comment to this post.
  • Cheers
Nov 23, 2015 | Heating & Cooling
What is the area of a circle if the circumference is 2 pi inches
area formula is PI x r squared
that is 3.1417 times the radius of the circle squared
example is:- 3.1417 times 3 inches squared =3.1417 times 3x3=3.1417x9=28.279 square inches if you want to work back from a circumference measurement, the formula for circumference is 2 x PI x radius or PI x diameter
if you have a circumference of 12 inches then the dia is calculated 12 inches = dia x PI to get the diameter , divide the 12 inches by PI and that will be the diameter so that is 12 divided by 3.1417 =3.819 inches
now you can go from the first formula the radius is the diameter divided by 2 so the radius will be 3.819 divided by 2 = 1.909 inches
so applying the area formula it becomes 3.1417 times 1.909 times 1.909 =11.458 square inches
to find your answer simply substitute the dimensions in place of the example figures.in the relevant formula.
Aug 24, 2015 | Office Equipment & Supplies
You are framing a rectangular print that is 10 inches wide and 34 inches long. this wall space has an area of 640 square inches. what is the width of the frame so that the framed print fits perfectly in...
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
Feb 16, 2011 | SoftMath Algebrator - Algebra Homework...
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Box dimensions
I've Got The Same Subs, I Got A Formula On The Net, Its Dimension Is Aprox 9 D X 24 H x15 W.
Although I Have Them In A Home Made Ported Box I've Made, Its Dimensions Are 8 D X 23 H X 17 W And Its Sound Pretty Damn Good. I Have A 2 Inch Round Port X 6 Inch Long. The Formula Says I Should Have A 3 Inch Long Tube.
Feb 23, 2008 | Volfenhag ZX-4712 Car Subwoofer
What are high resolution and standard resolution?
All pictures have 24-bit pixel depth, or 16 million colors at 144 dots per inch. The high resolution setting produces a standard size photo, 4.44" x 3.33" at 640 x 480 pixels. A wallet size photo of 2.22" x 1.67" at 320 x 240 pixels is produced using the standard resolution setting. Example: A picture with dimensions of 4.44" x 3.33" at a pixel count of 640 x 480 will have the same dpi as the same picture at a 320 x 240 pixel count with dimensions of 2.22" x 1.67" (dpi=144 x 144 or 20736 pixels per square inch). The larger picture will have a much higher resolution due to the fact that four times the pixels will define the same section of the picture in the larger photograph.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
