Question about Kitchen Appliances - Others
Cuisinart Cwc 1600, no cooling Cooling fan locked, replaced it. Still no fan , no cooling. Temp switch works & light. Help Tks Keith
emissionwiz
  • 77544 Answers
SOURCE: cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Posted on Aug 22, 2008
leetamara
  • 702 Answers
SOURCE: Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Posted on Sep 27, 2008
SOURCE: 2001 malibu 3.1 v6 cooling fans run all the time and temp gage
replace thermostat, this fixed my car, cooling fans keep coolant below temp guage parameters.
Posted on Feb 13, 2009
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I also had one of these CWC 900 units that quit working. The interior temp was 77deg F and the outside was 70 deg F.
The exterior panel was very warm to the touch where the heat exchanger was.
Like a previous person stated, there are two fans. One on the control unit board and then the main cooling fan for the exchanger. In my case, this main cooling fan had quit working - allowing excess heat to build up.
Solution: Unplug the unit! Remove the side panel of the CWC 900. First remove the 8 "finishing" plastic plugs that hide the screws. This was done with a sharp point on an ice pick to pry them out. Then remove the 8 screws with a torx T10 driver. At this point, plug the unit in and lower the temperature setting. In my case the small fan kicked on and the larger one did not. Un plug the unit. If you try and manually turn the fa you will feel resistance. Remove the cooling fan and black housing w/ 4 phillips screws. seperate the wires from the cable ties and then unplug the fan - you may have to remove a small amount of a plastic type glue to unplug the fan. Remove the fan from the plastic housing w/ 2 phillips screws. This is a fan made in China and I was unable to find a replacement on the web. Remove the center sticker on the back with the fan model number. Remove the center black plastic plug with a sharp point. You will now see the end of the shaft and a small split keeper ring. This ring is made of plastic - be gentle. Pry it open and remove it from the shaft (KEEP IT). Once the keeper is removed, you will be able to pull and seperate the motor from the fan blade and expose the shaft. I was not able to remove the small bearing from the motor so I wipe the shaft clean, applied white lithium grease and the re-assembled the unit. Fan spun freely. Put everything back together and the unit should be fixed!
Hoped this helped.
Posted on Feb 14, 2009
SOURCE: cooling fan switch/or sensor
The Coolant temp Sensor is located right under the top radiator hose (on the engine side), with a little black connector!, You might have to remove th etop hose to get to it with a deep socket and extension!.
Also Dont Forget to blled the coolant system by the bleeder valve uptop right near/above the coolant sensor!.(10MM Mini socket w/ extension IIRC!)
Posted on Sep 28, 2009
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Is there a replacement circuit board for the Cuisinart CWC-1600 unit?
The actual manufacturer of the circuit board out of China does not seek direct, but you may be able to order a replacement board through cuisinart support. More than likely your board is fine, but rather your power supply has failed. Check my post on how to replace the power supply for under $20
Jun 17, 2014 | Cuisinart CWC1600 Wine Cooler
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
My Cuisinart cwc-600 does not cool. It registers 45 degrees but is not cold enough to make white wine palatable. No matter where it is set, it seems to be a room temperature. We live in a small house so...
I have been all through these, and they are not very repair friendly. If it's under 3 years old Call Cuisinart, they will exchange it.
They are solid state cooled using a peltier chip cooler. There are 2 fans in the back cavity, and 1 inside. Remove everything from inside, and set the temp to cooling. Do all 3 fans run? If the inside fan does not run, no cooling. The fans are common 2 wire 12 volt computer fans, and available at computer parts stores that sell PC cases and components. Next is to check the cooler itself. Remove the inside rear cover. There's heatsink under the inside fan. Does it get cold when the fridge is running? If not, the next step you will need to get the back off. The Torx screws are special, but a quick slotting of the screw heads with a dremel or a hacksaw, and a regular screwdriver will remove them. Once off, note the red/black fan wires. Also see if there is a load of dirt in the heat sink. If it's plugged, no cooling. Back to the red/black wires. The fan wires are thin. The peltier cooler is heavier. Set to cool, Check for 12 volts on all 3 pairs of wires. If there's power, the fans run (inside and out) and the inside heat sink does not cool, the peltier chip is bad. It's major surgery to replace the cip, but it can be done, and there are scads of sellers on E-bay selling 60-90 watt peltier coolers that will work. They are standard millimeter square sizes, just match the thickness, 12-15 volts, and wattage (around 60-90).
If you are not getting power on the peltier cooler chip lines, there is a tiny fuse on the lower left of the circuit board. Check it.
These are not servicable from cuisinart. Even the silly screws to change the light bulb are security torx type. Fans are available at computer parts stores. Fuses at electronic supplies. The peltier chip can be had from E-bay. That circuit board is impossible to get. Any other parts are impossible to get to by the way it's built.
Jan 28, 2011 | Cuisinart Private Reserve CWC-600 Wine...
Cooling fan for s type jag
Hey there..my name is Keith..and i can think of 2 possibilities..1 is the fan motor needs to be replaced or 2...the temp sensor needs replacing..thats what tells the fan to turn on and off..i hope this helps
Jun 29, 2009 | 2002 Jaguar S-Type
Hoped this helped.
Mar 19, 2008 | Refrigerators
Kitchen Appliances - Others Logo
55 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
