Question about Samsung Washing Machines
How to remove Samsung pedestal drawer model#we356a5c/Xavier. There are no screws that I can see!
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
SOURCE: Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Posted on Aug 04, 2008
SOURCE: need to remove drawer from
I just removed the drawers, you need to remove one each 1/4" head sheet metal screw from the end closest tot he drawer front. this will allow you to slide the drawers out and clean the mess undere both the dryer and the washer. repeat steps to reinstall. Takes about 2 min to remove both doors, Hint: a 1/4 socket works better than a wrench.
Posted on Feb 14, 2009
SOURCE: how to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Posted on Jan 31, 2010
  • 6 Answers
SOURCE: need to remove the drawer
Two screws is all that needs to be removed. These screws have a nut so you will need a wrench. The screws are located at the front of the metal rail that the drawer rides on. Empty the drawer, remove the screws and slightly lift and pull the drawer free.
If you are having a problem with the door staying shut like I did the part responsible is the little white square box called a 'Latch' located at the front bottom of the casing, in the middle held by two screws. A black 'strike' on the door inserts into this Latch. If the strike is good the latch should be the problem.
Strike Part Number: 137006900
Latch Part Number: 137006200
Here is a web page with a break down of the parts: http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/All-Products-Parts/Model-EPWD15RR2/1412/0153050/R1007111/00001
Hoping the web page isn't against any rules, if so I'm sorry...
Posted on Dec 14, 2010
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Need to remove the drawer from the pedestal
Nov 20, 2010 | Electrolux 15 Silver Sands Pedestal...
How to remove drawer on pedestal
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
HOW DOES THE DRAWER TO MY PEDESTAL BASE MODEL SBSD137H5WW , SERIAL NO. HR124045G COME OUT SO I CAN SECURE THE SCREWS AT THE BACK INTO THE WASHER AT THE TIME OF INSTALLATION? MY WASHER IS A GE MODEL...
Went back to Lowes to talk to a sales personal. He informed me that there are two screws at the front of the drawer (one per side) After removing these screws (you will need to put them back after) the drawer will be removable from the pedestal base.
Nov 13, 2009 | GE WSXH208A Front Load Washer
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Replacement kenmore pedestal front drawer cover?
The pedestal should have it's own model number on it. Find the model number and contact Kenmore parts depot and they should be able to get you a front panel.
Dec 26, 2008 | Kenmore 15.5 in. Pedestal
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
I have a GE front loader on a pedestal & needed to remove the drawer. I got an answer from their website below. Basically, on this model, unscrew the hex-head screw at the FRONT of the side rails on each side.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SBSD137HWW&SITEID=GEA&TABID=4 Manuals & Documentation tab - page 2
May 09, 2008 | Washing Machines
Washing Machines Logo
163 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
