Question about Diesel Health & Beauty
My Mojito 50 was working ok from garage but i've not been on it yet as was waiting for new keeper paperwork. I topped it up with 5 of unleaded and now its not turning over at all. Any ideas?
Its not been used over the last 3 weeks. been on hols. I'm new to scootering and have not been on it since i bought it couple months ago. Came back from hols. It almost started but obviously out of petrol. i put a fiver in. the needle hasn't moved and although the petrol light comes on, just getting a dead tone from ignition. Is there any chance i got a diesel scooter or i've flooded it?
SOURCE: Geely Scooter
I believe that is the alarm telling you to add more oil to the resevior. I have a 2003 geely as well, and my owner's manual says there is an alarm for when the oil is low. Use a good 2 cycle injector oil from a motorcycle shop to get the best performance and avoid problems.
Hope it helps,
Criss
Posted on Jul 08, 2008
  • 41 Answers
SOURCE: Yamaha vino 50 cc scooter
hello, check to see if it is a switch (pull hand brake back when starting
Posted on Nov 25, 2008
my-mobility
  • 9 Answers
SOURCE: Scooter just stops
Battery connection problems cause the controller to overheat. Once you have allowed the electronics to cool down, all seems well again. Get on your knees and check that the battery terminals are secured very well. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: stock sym 125 scooter for almost 2 months not starting
check for fuel, spark, and air flow
Posted on Aug 30, 2009
SOURCE: Direct bikes scooter wont start
have dafier qt 50 starts first time on kick start,do a run about 10 miles runs ok, turn of motor, then it is very hard start.
Posted on Jan 25, 2010
2011 Aprilia Mojito 50 looking for coil pack resistance
Hi, Jordan for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Aprilia, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.apriliaforum.com/forums/showthread.php?161973-Testing-the-ignition-coil/page2
How to Test Stator Ignition CDi Piaggio 50cc Scooter
APRILIA MOJITO 125 2004 Manual
Products at Aprilia Genuine Parts Aprilia Parts Aprilia Spare Parts...
APRILIA MOJITO 125 01 2007 Manual
Dec 11, 2016 | 2004 Aprilia Mojito Retro 50
Why does a rear drum brake not work properly on an aprilia mojito
Hi Anonymous, you may need an adjustment or shoe replacement for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. https://www.tradebit.com/filesharing.php/search/0/2004+aprilia+mojito+retro+50
May 10, 2014 | 2004 Aprilia Mojito Retro 50
Aprilia mojito back fire on cold start
Hi Anonymous, if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove carburetor disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2004+aprilia+mojito+custom+150
Dec 03, 2013 | 2004 Aprilia Mojito Custom 150
My aprillia mojito 50cc headlamp won't work
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD Aprilia Mojito 50
Sep 10, 2012 | Aprilia Motorcycles
I have a aprilia mojito scooter 50cc it start ok but when i ref it it cut out straight away and they hardly no power when i set off ?
Check the spark plug is clean and gapped. Aprilia is a high performance bike and the spark plug does tend to foul up.
If the plug is clean check that the fuel is reaching the carburettor ok.
Hope this helps
regards
Graham
Apr 13, 2012 | 2008 Aprilia Mojito 50 Custom
My Genie Excelerator garage door blinks 5 blinks, and the garage door will go up but not down. just recently I've replaced the limitor down switch...?
I had the same problem, I unpluged the unit waited 30 seconds and then pluged it I. Again and I began working properly.
Oct 16, 2011 | Home Security
Not a problem, just a question: What is fuel/oil mix ratio on this unit? What type of oil? Unleaded gas ok, I'm assuming. thnx!
everything i have seen says 40:1 mix. most saw are 50:1 or 40:1. use 2 cycle oil and mixing instructions are on the bottle. unleaded is ok
Nov 13, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Instruction on replacing battery on aprilia mojito custom 50/150
Hi Lortiz657, for more information about your question please visit the website below. Good luck and have a nice day.
http://www.motorscooterguide.net/Manuals/Aprilia_Mojito50-150_Service_Manual.pdf
Apr 06, 2010 | 2005 Aprilia Mojito Custom 125
Which oil? New mojito rider
but it is a motorcycle. Am waiting for the taller sidestand too. A bit of a push to get her upright.Congrats!!!!!!!! I run Motul semi 15w-50. Try the Givi windshield...Big difference for me at 6'2.,,
Nov 10, 2008 | 2004 Aprilia Mojito Custom 150
Health & Beauty Logo
Top Diesel Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Diesel Health and Beauty Expert? Answer questions, earn points and help others
