Question about Coffee Makers & Espresso Machines
My Jura was turned off for the summer and now will not fill when it asks to press steam to fill. Any solutions?
4 Suggested Answers
SOURCE: refilling system
same problem.. "fill system press steam" but no water was flowing. The pump has an air bubble in it. capressa customer service advised to continue (up to an hour of retrying if necessary) pressing the steam button, let the machine rest for a few minutes and retry again and again until the water starts flowing. Sure enough, after 45 minutes, and 30 or so times of pressing the button, it started to work again. While I was wasting away my saturday morning with this, Williams Sonoma said that they would have the machine repaired at no charge and have it shipped back to me if I wasn't able to get it working. I've owned this machine for almost 5 years (bought in Jan '05) and this is the only time I have had a problem. ..and to be fair, I had let the machine sit for several weeks without use, or water in the tank, when I encountered this problem.
Posted on Nov 21, 2009
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
CoffeeLoverZ
  • 33 Answers
SOURCE: Hi, our Jura Impressa Xs90
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
Posted on Mar 28, 2012
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Apr 22, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Press steam fill water
You can check the water valve, it may become clogged. But you should not disassemble machine if you are not specialist. Contact Jura service center if your machine still under warranty.
Sep 25, 2013 | Jura Capresso Impressa S8 Coffee Maker,...
Hi, our Jura Impressa Xs90 keeps flashing 'fill system' & ' press steam'. There is plenty of water in it, we've tried removing the water and refilling. Doesn't work. If you press steam it just beeps...
May 02, 2011 | Jura Capresso Impressa X90 Espresso...
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
Machine says malfunction and won't froth milk
If you have a rotarywheel; Press and hold to enter the menu, turn to Maintenance, select Decalcify unit; empty tray as requested, fill up 600ml water in a container. Disolve 3 Descaling tablets in the water, and then fill it in the watertank. Press Maintenance button and you`re off.
If you don`t have a Rotary; Turn off the machine and let it cool down for a while, then push the Rinse/Maintenance button for a few seconds; then you will get the message Empty tray. Fill the solution in the watertank and press button.
It`s important that you use the right amount of water, or else the process will "never" finish.
Dec 24, 2008 | Jura Capresso Impressa S9 Coffee...
Refilling system
Run a clean cycle, might sort it out,
Sounds like it is scaled
Dec 14, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Changed Claris Filter-now says "fill system/press steam"
Probably have air in the system - it needs to be flushed, Run the tea portion hot water for a while. If not check the manual on how else to flush the system Gary
Apr 13, 2008 | Jura Capresso Impressa S9 Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
