Question about Whirlpool Washing Machines
Have a Whirlpool Washer-- completes all cycles but leaves small black residue specs in the tub and on the closes--- grease like composition-
    Top Expert:
  • Whirlpool Master
  • 80,668 Answers
The washer tube shaft seal is failing, that is grease.
Posted on Apr 18, 2017
Washer leaves a large deposit of black material on sheets after washing
i think you model has a tub clean mode. i would try to do that. basically no clothes, no detergent, just fill the bleach dispenser and run the tub clean mode. press power and then hold in the tub clean button on the right for 3 secs. then press start.
Mar 23, 2015 | LG Wm2301hw Front Load Washer 4.2 Cu. Ft...
Were there recalls on any of ghese models
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Apr 19, 2014 | Maytag Neptune Washing Machines
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
Black stains on door
If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
Best regards, --W/D--
Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
Our washer is leaving a greasy residue around and on the top of the drum.
If the age of your machine is over 10-12 years old, you could have a model that uses a transmission and the trans is leaking. If it is the transmission, it could be about a $150+ part.
Older washer designs used a motor to drive a transmission to agitate and spin the wash tub. As these get older, some develop small holes in the drive shaft (up under the agitator) which lets the trans grease get into the wash water. Our old washer lasted 23 years before the tub started to rust, so we decided it was time to get a new one, rather than put money into such an old machine.
IF your washer is older than 15 years, it might be starting to develop some other issues, such as rusting tub, etc., that could be costly to replace those parts, like the transmission, so you need to determine if
you want to repair or replace the machine.
If you can provide a model number, with all the alphas and digits, including the pre-printed ones on the label or tag, it could be confirmed that your washer uses a transmission and that is the likely source of the grease you're seeing.
Hope you find this Very Helpful and best regards!
Aug 23, 2009 | Whirlpool Washing Machines
Whirlpool Super Capacity Plus washer drum removal
What kind of residue? Grease? Sometimes a buildup of fabric softener will look like grease. If so, removing the agitator and inspecting it will show a buildup of fabric softener on underside. Rinse with hot water to remove. If you need to remove the inner drum, you will need a special tool for that. Try a local appliance parts business. They might loan or rent one, or sell you one. No filter to clean though. Grease should not be present as there is only the shaft of the transmission coming through a seal into the outer tub. Not likely to have grease migrate into tub. Fabric softener will be present on outer tub as well. Remove with hot water and plastic dish scrubber. Rinse and re-assemble washer.
Aug 01, 2009 | Whirlpool Washing Machines
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jul 13, 2008 | Maytag MAH55FLB Front Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
