Question about Simplicity Vacuums
My Simplicity 6870 vacuum won't run at times. Sometimes when I push the on button it will work while other times it won't. What could be causing this?
    Master:
  • 923 Answers
My first guess is that you have a damaged cord, or perhaps a dirty plug, or possibly even a bad outlet. There is a way to tell which, if any of those problems are the cause. Will you be doing the work, or someone else?
Posted on Apr 18, 2017
  • Wally Bottom
    Wally Bottom Apr 18, 2017
    I'll be doing the work
  • solver2010 Apr 18, 2017
    How long is the cord, and is that cord on a winder, or do you coil it up yourself before putting the unit away?
I believe my simplicity hose is clogged - how can I unclog it?
hoses seldom clog but the area around the head of the vacuum does
where the head is angled at the end of the wand is where items are caught and cause a blockage
Dec 16, 2016 | Simplicity Vacuums
Simplicity S38 vacuum wand wont work
There are a few things that can cause the wand to not work. I would suggest you make sure the spinning aspect isn't impeded by a string or wire. I would also check the suction of the hose itself. If the vacuum is too full, it won't be able to get a good suction through the hose, causing the want to not work.
Elisa Jed ' http://www.cleanerswarehouse.com.au
Aug 13, 2014 | Simplicity Vacuums
Simplicity symmetry vacuum stopped working
There is a reset button on the back that trips if the vacuum gets hot.
Jul 27, 2014 | Simplicity Vacuums
Belt replacement on simplicity synergy x9 series
Your simplicity has a lifetime belt. It has a sensor to shut the direct air motor off if something restricts the brushroll from from turning. You may save money in the long run by taking it to a simplicity or Riccar vacuum dealer.
Mar 22, 2014 | Simplicity 7250 Deluxe Vacuum
The vacuum does not start
Did you push the reset button on the rear of the vacuum. If it has. Overheated the reset will trip.
Mar 21, 2014 | Riccar 8900 Simplicity 7822, 7300, 7350,...
Sentry 3 series vacuum smelled hot, and now will not power up, changed bag (not over full)
There is a reset button on the back of the vacuum that shuts the power off if the motor gets too hot. Try pushing the little white button on the back. If it comes back on that means that there is probably a clog somewhere or the bag was too full.
Aug 10, 2013 | Simplicity Vacuums
My Siplicity canister vacuum turns on/off fine, but
sometimes the spring are sleep, you must replace the power brush button.
God bless you
Jun 19, 2012 | Simplicity Vacuums
After changing bag, won't run. Is there a reset somewhere?
Look in the back of the machine toward the bottom by the silver tag. Red or white reset button. the early models did not have this.
If you need any help contact me.
Tim
TheVacCenter.com
Jul 31, 2011 | Simplicity Vacuums
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Vacuums Logo
41 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
