Question about Filter Vacuums
I was cleaning the filter and the dust collection chamber and I think I got the battery wet! Red light comes on when plugged in but the blue ready-light does not- Help!! Have I refined it???!!!
SOURCE: filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Filter keeps clogging
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
RockyNR1
  • 324 Answers
SOURCE: sweeper head
First - press the circuit breaker button.
If no luck:
1. Make sure you have connected it properly (see diagram here)
2. If you connected it right - try bypassing circuit breaker.
3. Still does not work - make sure the connectors are reconnected properly.
This should take care of the problem.
Posted on Oct 30, 2008
  • 6 Answers
SOURCE: RED Flashing clean button with NO START
Try wiping off the cliff sensors, and cleaning the drive wheels. Download the user guide, if you don't already have one.
Posted on Oct 28, 2009
bduxbury
  • 3982 Answers
SOURCE: Dc59 bad smell Have cleaned the filter/canister correctly. however the smell appears to be coming from the dust which collects under the purple mesh how do I clean that out? Thanks
contact dyson support check www.dyson.com
whatever country you are from put country after the .com
eg australia is www,dyson.com.au
https://www.dyson.com.au/support/dc58-dc59/dc59-animal/maintaining-your-dyson-machine/wash-the-filter-video/not-resolved/obtain-telephone-support
Dyson has excellent customer support and having used there customer support I recommend giving them a call.
Posted on Jul 07, 2016
AndrexT
  • 19111 Answers
SOURCE: My Dyson V6 Motorhead runs intermittently. I have cleaned the collection chamber but still not fixed. Help!
Return it and have it fixed under warranty.
https://www.dyson.com/support/warrantyterms.aspx
Posted on Dec 05, 2016
Hi, My Electrolux twin clean vacuum has both red and blue lights flashing and I can not get it to turn on to clean the filters. Any suggestions
Try taking the twin filters outside - also take a dustpan brush and tap the filters gently on the bottom, then brush the dust away as it comes out. This can take quite some time, and you will find that LOTS of compacted dust will come out!
Feb 20, 2011 | Electrolux Twin Clean Bagless Canister...
Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
No more steam coming out.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Apr 19, 2009 | Bissell 1867 steamMOP Stick Vacuum
DUST NOT COLLECTING IN THE DUST BAG
sounds like the bag if full and the is coming out from around the bag.make sure the bag is in correctly and tight
Jan 07, 2009 | Kenmore Progressive Bagless Upright with...
I want to know how remove the filter to clean or replace on my fm744h fantom vacuum
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at TotalVac.com
Nov 28, 2008 | Fantom Vacums FM744H Vacuum
Electrolux Z8240 model vacuum cleaner flashing red & blue 1 every 6 seconds. What could be wrong with it
Inside ,the dust collection container, there at the far end is a white cone shape (another filter). I think you may find this covered in lint etc and if you reach in with your hand you can just pull the stuff off. Happened to me around the two month mark and I THINK, so far, so good. My machine is now not switching off and flashing lights at me and the suction is back to fabulous. Found this information on another obsure website. You would think electrolux would mention it in their "Troubleshooting Guide" GOOD LUCK
Oct 02, 2008 | Vacuums
Troubleshooting
Plug the hose into the other side of the unit. One end pushes air and the other side draws in the air. Now drywall dust will clog your filter quickly. Clean the filter often. Do not clean dust without the filter. It will get all over everything!
Sep 01, 2008 | Craftsman 17029 Wet/Dry Vacuum
Suction
There is a float in the water collection chamber that closes off the opening below the filter. Make sure that the float is moving freely and the hole under the filter is not obstructed. Reply if this is not the problem, I have one sitting here that I can look at for other possibilities.
Jan 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
21 people viewed this question
Top Filter Vacuums Experts
gbob59
Lawrence Oravetz
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
