Question about The Kitchen Appliances - Others
How to cook a pre-baked spiral ham direction say 15 minutes per pound its 8.5 pounds at 15 minutes per pound Oven temp at 250 I got that, But do I need to poke holes in the Ham for brown sugar glaze?
    Top Expert:
  • The Master
  • 78,289 Answers
All you need to do is wrap the ham tightly in foil and the last 15 minutes put the glaze on, let stand 5 minutes before serving. No holes!
Posted on Apr 18, 2017
How long to boil a pre-cooked, bone-in ham weighing 10.88 pounds?
I am guessing you are baking or broiling a ham, the amount of time is usually @325F 10-15 minutes per pound. So a 10-11 lb ham would be 1 hour to an hour and a half. Boiling a ham that size would be same amount of time.
Dec 11, 2017 | Kitchen Appliances - Others
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
How long to cook a 19 pound turkey
Cooking times will differ depending on whether your bird was purchased fresh or frozen. Plan on 20 minutes per pound in a 350 degree F oven for a defrosted turkey and 10 to 15 minutes per pound for fresh. 4. A turkey will cook more evenly if it is not densely stuffed.
Best Turkey Cooking Tips : Food Network
www.foodnetwork.com/holidays-and-parties/articles/top-turkey-tips.html https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+long+to+cook+a+19+pound+turkey
Nov 22, 2016 | Grilling
How long to heat a fully cooked ham and what temp
Preheat the oven to 325°F. Place the ham on a rack in a shallow roasting pan. For a whole 10- to 15-pound ham, allow 18 to 20 minutes per pound; for a half--5 to 7 pounds--about 20 minutes per pound; or for a shank or but portion weighing 3 to 4 pounds, about 35 minutes to the pound.
Nov 26, 2015 | Hearthware Home Products Nuwave Pro...
How long do I bake a spiral pre-cooked ham that weight 9.37 pounds? The directions read 10-12 minutes per pound. How long is that is hours and minutes? It's for Easter. Thank you.
A bit late now ,but should have been cooked at approx. 1hour and 30 minutes depending on the heat of the oven, and checking for doneness.
Apr 04, 2015 | Kitchen Appliances - Others
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
How do I cook a smoked ham in my rival elect. oven
Smithfield type country ham? Use the insert to soak it (I do two days in the fridge in skim milk made from nonfat dry milk), drain, add water and simmer in the roaster:
  • Bring water to 180 degrees (not quite simmering). Cook to 160 degrees internal temperature (or about 25 minutes per pound). Add water to keep ham covered.
  • Take ham from the pan and while warm, remove the skin carefully without tearing the fat. Dot the surface with cloves if desired, then sprinkle with brown sugar and bread crumbs
  • Drain roaster
  • Bake 15 minutes at 400 degrees (or long enough to brown nicely).
  • This makes the ham tender and not as salty as straight roasting.
    Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    Cook Times
    For the turkey, should be between 20 - 25 minutes per pound. About 20 minutes per pound for the ham, if memory serves. This is after your smoker comes up to temp and you start to see smoke from your smoke chips/chunks.
    At about 20 minutes per pound, take the temp of the ham and turkey with a good instant read meat thermometer.
    Also, I generally don't use water in the water pan for hams and turkeys, but that is a personal preference. If you put water in your pan, it'll probably take a few more minutes per pound.
    Pat
    Nov 21, 2007 | Char-Broil Electric H2O Smoker
    Kitchen Appliances - Others Logo
    94 people viewed this question
    Top Kitchen Appliances - Others Experts
    Bilral
    Level 1 Expert
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
