Question about Roketa 150cc cheap Scooters
The six pin plug from the bike shows all pins shorted to ground. This on the headlights. I have a 2008 Roketa 250. Also I cannot switch from lo to hi.
    Top Expert:
  • Roketa Master
  • 39,882 Answers
Hi, David for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Roketa, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda CN250 Owner Manual
http://store.oohla.com/storefiles/terminatorscooter//download/accessory/2658/sms.pdf
MC54
ROKETA atv exercise fitness dune buggies scooter gokart dirtbike moped...
Roketa Scooters
Posted on Apr 21, 2017
Why does my 2009 Bajaj Pulsar 200f headlight only come on after 5 sec of the engine starting? Is there any solution to turning on the light without starting the bike?
Hi, Em you may have a battery issue make sure connections are clean and tight if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Pulsar 220 DTSi 17 Known Problems and Its Resolutions
how to fix electric start and power of bajaj motor bike
http://nexgenbikes.com/site/wp-content/uploads/2013/05/Bajaj-Pulsar-200-NS-Owners-Users-Manual.pdf?2fb5c5
Download Bajaj Pulsar 200 NS Spare Parts Catalog Manual
Pulsar Do It Yourself Engine Oil Change
Nov 30, 2016 | 2008 Bajaj Pulsar 200 DTSi
WHY MY 2008 ROKETA 250CC MC-68A IS NOT GETTING NO SPARK, I HAVE CHANGE STATOR, IGITION SWITCH, CDI BOX, BUT NOTHING. HELP
Hi, Donald and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
Roketa 250cc MC54 no Spark SCOOTER PROFESSOR
Honda Ch 250 Your service information center
http://roketapartsdept.com/
http://www.scooterdynasty.com/manuals/MC-54B-250%20User's%20Manual.pdf
Oct 16, 2016 | Roketa 50 Scooters
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
START BUTTON AND HEADLIGHT
Hi, Ludwig if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Trouble shooting headlight Yamaha XS650 Forum
Headlight issue
Yamaha XS650SE Shop Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Apr 18, 2014 | 1980 Yamaha XS 650 G
Lights go dim when rev engine
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
headlights dim when revved up General Dirt Bike Discussion
ATV Connection
Honda ATC200E Headlights are dim while at full throttle brighter at idle
Lights flicker when idle and dim when rev
Stator Question
Jan 22, 2014 | Yamaha Motorcycles
2002 Honda CR 250 R headlight not working
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
cr250 headlight fitment 2002
CR250R headlight
CR250 2002 2003 pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://owners.honda.com/assets/ownerlink/model/own_man/powersports/2007/2007_cr250r.pdf
Sep 09, 2013 | 2002 Honda CR 250 R
Yamaha virago 250 high beam doesnt work?
Things to check if headlight doesn work motorcycles
ViragoTechForum com
Yamaha XV250G Supplementary Service Manual
Yamaha VIRAGO XV250R Owner Manual
Sep 07, 2012 | Yamaha Virago 250 Motorcycles
I have a 2008 Yamaha YZF-R1. Both my low beam and high beam head lights do not turn on when I start my bike. The Auxillary lights come on, and the high beam indicator is on but does not change even if I...
Hi, Tom if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
headlights not working
2001 R1 Headlights Gauges Help
Yamaha R1 YZFR1 2007 2008 Service Repair Manual Download Download Manuals...
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 10, 2011 | 2008 Yamaha YZF-R1
My headlight will turn off shortly after starting the bike and won't turnm back on..Tested wires and not getting power..Then 2 days later husband started bike and headlight turned on, but shuts off...
Hi, Laura_hunt_c if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
headlights turn off when start the bike wtf
Electrical fault 1982 Yamaha Virago 920J
http://www.groussin.com/multi/XV250.pdf
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Jun 23, 2009 | 2005 Yamaha Xv 250 Virago S
2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Jul 28, 2008 | 2002 Pontiac Grand Prix
Roketa 150cc cheap Scooters Logo
19 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
