Question about Lands Phones
Answering machine is on but won't pick up the messages
The messages left on the phone are not recognized. It says no message when we know there is one
  • 13433 Answers
SOURCE: Erased messages - digital recovery?
Sorry, the digital memory can't be restored ones the power is cut or the messages are erased. Some high tech lab somewhere FBI/CIA maybe just maybe could do it but no noting we can do about it.
you can try a old trick of holding down the play button for 10 or more seconds.
I'm really sorry.
Posted on Jul 04, 2008
axebro112
  • 56 Answers
SOURCE: How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Posted on Apr 26, 2009
SOURCE: Phone won`t switch to answering messages, OGM says
Phoned Help Line
Posted on Jun 24, 2009
SOURCE: Answering Machine not recording!
I had the same problem with my Siemens Gigaset answering machine and I fixed by changing the sound quality of my Vonage line to the highest available (=90Kbps).You should be able to change this in the Features -> Bandwidth Saver webpage on Vonage's website.
Posted on Feb 24, 2012
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
I have a XS1455 answering m/c. Have a problem
Messagebank provides a personal answering service if your phone line is busy or you can't get to the phone. You don't need extra equipment like answering machines, and you also get greater flexibility on call waiting- if you don't want to interrupt your call, let messagebank take your message. Let me know if this answers your question. Master FixYa: saailer@att.net
Dec 05, 2009 | Uniden 2.4 GHz Expandable Phone System...
Retriving messages remotely
Hi Ern, Usually the phone has a default code you dial when you attempt to get messages from your home answering machine.
Try calling your home, let the machine pick up, after your message is heard dial 1234. Your machine should recognize the tones and play your mesages back to you. I just happened to read that earlier today while setting up a new message on our office phone.
Hope this helps, RadioWidgets
Jan 30, 2009 | GE 25942GE2 Cordless Phone System
Talking on phone,someone calls in & leaves message, can't locate
Thanks for the opportunity to help with your problem. If you also have voice mail through your phone service provider, it's possible that while you are on the phone, the incoming call is "waiting" (meaning you are hearing a beep while you are still talking assuming you have call waiting). If you don't pick up the incoming call, your caller will hear your "voice mail" message and leave a message. However, your answering machine will not indicate that you have a message.
If my assistance was of any benefit whatsoever, please give me a rating so I can continue to improve my service. Thanks for using FixYa.com.
Jan 22, 2009 | Panasonic KX-TG5632 Phone
External Answering Machine Hook up with M7310
Even though the plug that plugs into the wall on an M-7310 looks like the same plug that the answering machine has, it's function is completely different. The information passed on the single pair of wires is enough to make a 24 button 10 button or 8 button system phone work, has no ringing voltage or dial tone for a single line device like your answering machine.
A Nortel system has ports that have that information, but most likely the answering machine was installed BEFORE the phone system lines, which means it only answered the first line.
Try plugging your answering machine into the EXACT location it was before.
Carl
Jan 09, 2009 | NorStar M7310 Corded Phone
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Messages
Do you have a voicemail system with your phone carrier? My answering machine is not set to pick up messages but blinks when I have a message in my phone carriers voicemail system.
Jun 04, 2008 | GE 25942GE2 Cordless Phone System
Phone is not recording all messages left
The 25414RE3 isn't the model with the answering machine. The one that has the answering machine is the 25415RE3.
As for the problem, does the answering machine part of the unit actually pick up the line? Does it announce your pre-recorded message? Does it just not record the caller's response?
Sep 08, 2007 | RCA 25414RE3 Corded Phone
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
