Question about Kitchen Appliances - Others
How to cook a pre-baked spiral Ham say oven temp @ 250 8,5 lbs @ 15 minutes per pound do I need to poke hole in it?
2 Suggested Answers
emissionwiz
  • 78267 Answers
SOURCE: How to cook a pre-baked spiral ham direction say 15 minutes per pound its 8.5 pounds at 15 minutes per pound Oven temp at 250 I got that, But do I need to poke holes in the Ham for brown sugar glaze?
All you need to do is wrap the ham tightly in foil and the last 15 minutes put the glaze on, let stand 5 minutes before serving. No holes!
Posted on Apr 18, 2017
Cooking time for ham
Oven.
Preheat oven to 325°F.
Place ham in ½-1 inch of water on bottom of baking pan and cover with lid or seal with foil. Bake approximately 15 minutes per pound or until an internal temperature of 140°F is reached
Mar 30, 2018 | Grilling
How long to boil a pre-cooked, bone-in ham weighing 10.88 pounds?
I am guessing you are baking or broiling a ham, the amount of time is usually @325F 10-15 minutes per pound. So a 10-11 lb ham would be 1 hour to an hour and a half. Boiling a ham that size would be same amount of time.
Dec 11, 2017 | Kitchen Appliances - Others
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
How long to heat a fully cooked ham and what temp
Preheat the oven to 325°F. Place the ham on a rack in a shallow roasting pan. For a whole 10- to 15-pound ham, allow 18 to 20 minutes per pound; for a half--5 to 7 pounds--about 20 minutes per pound; or for a shank or but portion weighing 3 to 4 pounds, about 35 minutes to the pound.
Nov 26, 2015 | Hearthware Home Products Nuwave Pro...
How long do I bake a spiral pre-cooked ham that weight 9.37 pounds? The directions read 10-12 minutes per pound. How long is that is hours and minutes? It's for Easter. Thank you.
A bit late now ,but should have been cooked at approx. 1hour and 30 minutes depending on the heat of the oven, and checking for doneness.
Apr 04, 2015 | Kitchen Appliances - Others
How do I cook a smoked ham in my rival elect. oven
Smithfield type country ham? Use the insert to soak it (I do two days in the fridge in skim milk made from nonfat dry milk), drain, add water and simmer in the roaster:
  • Bring water to 180 degrees (not quite simmering). Cook to 160 degrees internal temperature (or about 25 minutes per pound). Add water to keep ham covered.
  • Take ham from the pan and while warm, remove the skin carefully without tearing the fat. Dot the surface with cloves if desired, then sprinkle with brown sugar and bread crumbs
  • Drain roaster
  • Bake 15 minutes at 400 degrees (or long enough to brown nicely).
  • This makes the ham tender and not as salty as straight roasting.
    Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    How to heat a bone in spiral ham
    You could heat it on low power in the microwave at about 50% power for about 10 minutes, let it sit for a few minutes, check the temp around the bone, and do it again for another 2 minutes at a time until it gets to whatever temp you prefer. If you do use the roaster, put a cup of water in the pan, cover the ham, and heat at about 300 for about 30 minutes. If you want a little variety, instead of water you could pour a cup of Coke or pineapple juice over the ham, then cover and heat as noted above.
    Apr 11, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    Cook Times
    For the turkey, should be between 20 - 25 minutes per pound. About 20 minutes per pound for the ham, if memory serves. This is after your smoker comes up to temp and you start to see smoke from your smoke chips/chunks.
    At about 20 minutes per pound, take the temp of the ham and turkey with a good instant read meat thermometer.
    Also, I generally don't use water in the water pan for hams and turkeys, but that is a personal preference. If you put water in your pan, it'll probably take a few more minutes per pound.
    Pat
    Nov 21, 2007 | Char-Broil Electric H2O Smoker
    Kitchen Appliances - Others Logo
    27 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Irene Tulloch
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
