Question about Measuring Tools & Sensors
Where do I find where the spark plug is on Model 20M114-1358-E1?
    Master:
  • 604 Answers
On the head,look for number 337,
where do I find where the spark plug is on Model 2 - capturebbbb-hz4tw1xyuobiz2xvp5dkpwtl-3-0.png
Posted on Apr 18, 2017
I have a model 44P777, Type 0412 E1. I need the intake rocker setting and the exhaust rocker setting. I also need the spark plug setting. Thank you.
You can set your valves at .004 thousandths, and the spark plug is set at .030 thousandths. GOOD LUCK FRIEND.
Sep 16, 2014 | Garden
Why Spark on Briggs and straiten motor?
Does it have a shutoff wire on the carburetor?
Use a meter to check the coil at the magneto - if that coil reads "open" (no continuity), then it's bad & needs replacement.
Jul 26, 2014 | Garden
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Briggs and stratton engine model #31H777,type0297 E1,code041014ZA-motor turns over but won't start-getting fire at the plug also plug is wet with gas.
there are the basic things for an engine to start. air, fuel, and spark. if you are getting spark at the plug one down. try taking your air cleaner off and spray starting fluid into carb with choke open then close. if it starts and runs a litlle then dies then you have a fuel problem. take carb off and clean real good take bowl off and clean with carb cleaner. that should solve you problem if not let me know
Dec 24, 2010 | Garden
No fire to spark plug
If you have no spark on either spark plug then more than likely the coil is defective. Check all wiring before proceeding. The coil looks like this. 28596c2.png
Apr 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Spark plug gap for kawasaki zx600 e-1
I have an E1 and I set my spark gaps from 0.7-0.8 millimetres. I also service an E3 and the gaps are set the same on that one as well
Aug 08, 2009 | 1993 kawasaki ZZR 600
Measuring Tools & Sensors Logo
142 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
